Author Topic: LISP to draw circle and make block  (Read 2288 times)
like_citrus
« on: May 20, 2022, 10:36:49 AM »
I wanted to make this into a LISP:
- 1. Draw a circle (ask user for Diameter or Radius).
- 2. Place in a layer called "Fulcrum", the layer already exists.
- 3. Make it as a block using something similar to the code (mostly by others) below. The block goes in the currently used layer, typically "0".
- 4. Place the block by clicking the cursor at any point the screen. Prefer to snap to something if possible.
Understand it's a lot of work for a simple thing, but I typically draw this way, starting a block with a circle as an anchor point, and then editing in place.
(defun c:MakeBlock (/ bkn eee i ndx nm ssst st)
(if (and (setq ssst (ssget)) (setq st (getpoint "\nPick Base Point: ")))
(progn (setq ndx 0)
(setq time (rtos (getvar "CDATE") 2 6)) ; Format YYYYMMDD.HHMMSS
(setq year (substr time 3 2)) ; Two digits instead of four
(setq month (substr time 5 2))
(setq day (substr time 7 2))
(setq hour (substr time 10 2)) ; Increment of 3 from day to account for "." character
(setq minutes (substr time 12 2))
(setq seconds (substr time 14 2))
(while (tblobjname "block" (setq nm (strcat "Block-" year month day hour minutes seconds))))
(entmake (list '(0 . "BLOCK")
'(100 . "AcDbEntity")
'(67 . 0)
'(8 . "0")
'(100 . "AcDbBlockReference")
(cons 2 nm)
(cons 10 st)
'(70 . 0)
(repeat (sslength ssst)
(entmake (cdr (entget (ssname ssst ndx))))
(entdel (ssname ssst ndx))
(setq ndx (+ 1 ndx))
(entmake '((0 . "ENDBLK") (100 . "AcDbBlockEnd") (8 . "0")))
(entmake (list (cons 0 "INSERT")
(cons 2 nm)
(cons 6 (getvar "CELTYPE"))
(cons 8 (getvar "CLAYER"))
(cons 66 0)
(cons 10 st)
(cons 41 1)
(cons 42 1)
(cons 43 1)
(cons 50 0)
(cons 71 0)
(cons 44 0)
(cons 45 0)
mhupp
Re: LISP to draw circle and make block
« Reply #1 on: May 20, 2022, 09:53:13 PM »
You want to have multiple unique blocks? because that code is generating a random name every time its run.
why not just make a dynamic block that has the radius constrained when you insert it will ask for radius.
like_citrus
« Reply #2 on: May 20, 2022, 10:25:24 PM »
Yes they are all unique. That's the reason for the date stamp, may not be the best method but it works for me.
A regular block is better, as I edit by "Edit block in place" command, and can see other objects in the background.
mhupp
« Reply #3 on: May 22, 2022, 12:21:36 AM »
Just making sure you wanted all unique blocks. This will ask for radius and center point. make the circle on Fulcrum layer. and then the block is created on the current layer.
this command runs until canceled either hit esc or skipping input on the radius or point.
  1. ;;----------------------------------------------------------------------;;
  2. ;; CREATE CIRCLE BLOCKS WITH UNIQUE NAME
  3. (defun c:CirBlock (/ rad pt blkname)
  4.   (setvar 'cmdecho 0)
  5.   (while (and (setq rad (getreal "\nCircle Radius: ")) (setq pt (getpoint "\nPick Center Point of Circle: ")))
  6.     (entmake (list '(0 . "CIRCLE") '(8 . "Fulcrum") (cons 10 pt) (cons 40 rad)))
  7.     (setq blkname (strcat "Block-" (menucmd "M=$(edtime, $(getvar,date),YYMODDHHMMSS)")))
  8.     (vl-cmdf "_.Block" blkname "_non" pt (entlast) "")
  9.     (vl-cmdf "_.Insert" blkname "_non" pt 1 1 0)
  10.     (prompt (strcat "\nBlock [" blkname "] Created"))
  11.   )
  12.   (setvar 'cmdecho 1)
  13.   (princ)
  14. )
--edit
if you just want to run once change the while to if
« Last Edit: May 22, 2022, 12:37:10 AM by mhupp »
like_citrus
« Reply #4 on: May 22, 2022, 08:19:27 PM »
Hi, thanks this is getting close.
- How do you make it Escape automatically so it only runs once.
Is this what the "If" is supposed to do? If I change "While" to "If", it doesn't work, it says Unknown command.
- Also how do you place circle inside the block in the layer named Fulcrum. The block is in then in the current layer.
mhupp
« Reply #5 on: May 22, 2022, 10:07:03 PM »
(if (and
only runs once if conditions are met
if you have more then one line of code you have to wrap it with (progn sorry forgot to mention that.
(while (and
run as long as conditions are met (inputs for radius and center point)
think of it as a if loop
  2. ;; CREATE CIRCLE BLOCKS WITH UNIQE NAME
  5.   (if (and (setq rad (getreal "\nCircle Radius: ")) (setq pt (getpoint "\nPick Center Point of Circle: ")))
  6.     (progn
  7.       (entmake (list '(0 . "CIRCLE") '(8 . "Fulcrum") (cons 10 pt) (cons 40 rad)))
  8.       (setq blkname (strcat "Block-" (menucmd "M=$(edtime, $(getvar,date),YYMODDHHMMSS)")))
  9.       (vl-cmdf "_.Block" blkname "_non" pt (entlast) "")
  10.       (vl-cmdf "_.Insert" blkname "_non" pt 1 1 0)
  11.       (prompt (strcat "\nBlock [" blkname "] Created"))
  12.     )
  13.   )
  14.   (setvar 'cmdecho 1)
  15.   (princ)
  16. )
The lisp is making the circle on that layer on line 7
when the block is inserted on line 10 its to the current layer.
« Last Edit: May 22, 2022, 10:12:33 PM by mhupp »
like_citrus
« Reply #6 on: May 22, 2022, 10:14:39 PM »
Thanks, and apologies for not reading the code for the Fulcrum layer, as I didn't have it in the drawing I tested.
With the code above, for running once, I still get an error message:
Command: CirBlock
Unknown command "CIRBLOCK".  Press F1 for help.
mhupp
« Reply #7 on: May 23, 2022, 08:43:20 AM »
How are you loading the lisp?
appload
like_citrus
« Reply #8 on: May 23, 2022, 07:40:46 PM »
Yes, with appload.
mhupp
« Reply #9 on: May 24, 2022, 07:31:24 AM »
IDK should be able to run. double check your loading the right file.
like_citrus
« Reply #10 on: May 24, 2022, 07:51:27 PM »
Yes, I definitely have the right files as I have tested both with "while" and "if".
BIGAL
  • 40 + years of using Autocad
« Reply #11 on: May 24, 2022, 11:48:52 PM »
Just a side comment why not just make a block with a circle rad 1 then use scale to change.
« Reply #12 on: May 25, 2022, 12:20:13 PM »
Agreed .. and make it scale uniformly.
like_citrus
« Reply #13 on: May 25, 2022, 08:37:46 PM »
Would this resolve the issue of Escape after block is inserted?
like_citrus
« Reply #14 on: May 26, 2022, 02:05:26 AM »
This is finally working, I don't know why it wasn't before as LSP file was saved after changes.
Was there a way to use diameter as well as another option?
