Author Topic: Triang V0.6.7 surface volume command  (Read 1049 times)
ish0000
  • Mosquito
« on: May 20, 2022, 09:33:50 AM »
Dear team,
Please explain how to find tin surface volume by Triang V0.6.7.lsp.?.
what is the command TO FIND for surface volume.?
If it is not in Triang V0.6.7 program, please add code for surface volume AND SURFACE BOUNDARY PLINE ALSO.
AND
Triang V0.6.7.lsp  [IS THIS UPDATE VERSION OF LISP ?]
thanks
« Last Edit: May 21, 2022, 12:58:11 AM by ish0000 »
ish0000
  • Mosquito
Re: Triang V0.6.7 surface volume command
« Reply #1 on: May 25, 2022, 02:07:37 AM »
Team , any possibility ?
AMC
  • Mosquito
« Reply #2 on: May 26, 2022, 03:29:45 AM »
Hi, I did something like this a while back.
I basically converted the 3DFACES to SURFACES then I did a UNION on certain 3d faces to create 3 distinct surfaces after witch you can apply SURFSCULPT to create a 3DSOLID out of the 3 surface.
The attached 3d dwg details the same process I described, sadly this method is a bit of work
Hope this helps.
PM
« Reply #3 on: May 26, 2022, 10:43:26 AM »
Hi AMC. This method gives correct results? If you cut some cross sections you will have the same result ?
thanks
ish0000
  • Mosquito
« Reply #4 on: May 28, 2022, 07:08:52 AM »
sir , any easy method for surface volume like lisp code, macro, or add in tools for autocad.
thanks
