Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
LISP to insert block and rename
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: LISP to insert block and rename (Read 257 times)
like_citrus
Newt
on:
May 15, 2022, 10:51:06 PM »
Hi, is there a LISP anyone has to insert a block from another drawing and rename it with a suffix, to differentiate from the original block.
Something like Open, Select file, Paste, Rename with suffix.
Logged
mhupp
Newt
Re: LISP to insert block and rename
Reply #1 on:
May 16, 2022, 03:04:46 PM »
For importing blocks
http://www.lee-mac.com/steal.html
This is what i use to rename blocks.
Code - Auto/Visual Lisp:
[Select]
;; Add Prefix/Suffix to Block Name
defun
C:BLKRENAME
blklst SS blk lst c a n
vl-load-com
setq
blklst
vla-get-Blocks
vla-get-activedocument
vlax-get-acad-object
prompt
\n
Select Block(s) or Enter To Rename All"
if
or
setq
ss
ssget
0
"INSERT"
setq
ss
ssget
"_X"
0
"INSERT"
foreach
e
vl
remove
if
listp
mapcar
cadr
ssnamex
ss
setq
blk
cdr
assoc
2
entget
e
;Get Block Name
if
not
vl-position
blk lst
;If Block Name is not in List Add
setq
lst
cons
blk lst
setq
c
0
;Count
initget
"Prefix Suffix"
setq
rep
cond
getkword
\n
Specify your aim [Prefix/Suffix] :"
"Suffix"
cond
rep
"Prefix"
setq
prfx
getstring
\n
Enter Prefix: "
foreach
n lst
vla-put-Name
vla-item
blklst n
strcat
prfx n
setq
c
1+
c
rep
"Suffix"
setq
sufx
getstring
\n
Enter Suffix: "
foreach
n lst
vla-put-Name
vla-item
blklst n
strcat
n sufx
setq
c
1+
c
prompt
strcat
\n
rtos
c
2
0
" Block(s) Renamed"
princ
Logged
like_citrus
Newt
Reply #2 on:
May 16, 2022, 07:45:47 PM »
Thanks for sending this. I'll look into it soon.
Logged
ScottMC
Newt
Reply #3 on:
May 17, 2022, 08:57:23 AM »
Check out this persons helpful library.
http://www.lee-mac.com/copyblock.html
Logged
like_citrus
Newt
Reply #4 on:
May 17, 2022, 08:03:24 PM »
Thanks, will do.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
