My company is switching from SHX to TTF fonts. Historically we write our drawing notes in Word, convert to an .Ans file, and then a custom lisp reads the .Ans file line by line and imports them into CAD. Each line being its own text object. The
Please you do not write documents.DOc inside model-space.Dwg
because you slow down too much your/s the speed Acad, and
you generate too many incompatibilities with Revit.exe, Briscad.exe.ProgeCad, NanoCad
I think worst .. after i got experienced with others... O
=another method, We can" Transpile DOc to RegenRTF.lsp "
The programe "RegenRTF.lsp" create the file.doc on disk, reading
information/s from acad.exe
=The RegenRTF.lsp read information/s from files*.cpxml and
the RegenRTF.lsp create the file "Drawing1__203114.doc"
the RegenRTF.lsp input *.cpxml and export the file "Drawing1__203115.doc"
Best Regards...MsWord.exe si too powerfull with processing the file*.doc
Other companies are rejected the operations
importing the *.doc inside Model-space.dwg
