Author Topic: autload wont be recognised by 2023  (Read 981 times)
Shay Gaghe
« on: May 09, 2022, 09:48:23 AM »
hi
ive developed addon for autocade and im using the Autodesk autoloader mchanism,
in 2020 it works fine but with 2023, its not even recognized
im using the .bundle structure
C:\Users\WIN10\AppData\Roaming\Autodesk\ApplicationPlugins\PVC.bundle\Contents\Windows\2023
any idea?
Tx
Shay
Re: autload wont be recognised by 2023
« Reply #1 on: May 09, 2022, 10:13:25 AM »
Did you update the PackageContents.xml file to specify the use of the new file?
jtoverka
« Reply #2 on: May 09, 2022, 10:25:38 AM »
I had this issue, but I specified the following in the xml file:
    <RuntimeRequirements OS="Win32|Win64"
                         Platform="AutoCAD*"
                         SeriesMin="R19.0"
                         SeriesMax="R24.0" />
The SeriesMax to include AutoCAD 2023 is R24.2
Shay Gaghe
« Reply #3 on: May 10, 2022, 12:05:38 AM »
hi
i have tried lots of things but nothing,
ive installed addon that support 2023 in order to see the stracture,
i was amazed the partial is not listed but appear
any idea? see attachment
tx
Shay
