Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
I'm blind today or something
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: I'm blind today or something (Read 774 times)
jlogan02
Bull Frog
on:
May 05, 2022, 04:31:59 PM »
I'm getting an "extra right paren" error. For the life of me I can't see it. I've just started using Visual Studio Code
and like the fact that it's showing the last closed paren (defun) in red, indicating something is wrong.
Help says to...
Click to the right of an open parenthesis or left of a closing parenthesis, and press Shift+Alt+RightArrow 2 (or 3) times. As I see it, the error is somewhere in my "error" handler, but I'm not seeing it.
Code - Auto/Visual Lisp:
[Select]
defun
C:LayGrpFltr
*error*
defun
*error*
msg
if
not
member
msg '
"Function cancelled"
"quit / exit abort"
princ
strcat
\n
Error: "
msg
princ
rtos
getreal
\n
Press Esc to exit, press Enter to force an error ..."
princ
setvar
'cmdecho
0
command
"._layer"
"Make"
"TBLK_BORD_LINES"
"C"
"WHITE"
"TBLK_BORD_LINES"
command
"._layer"
"Make"
"TBLK_BORD_TEXT"
"C"
"GREEN"
"TBLK_BORD_TEXT"
command
"._layer"
"Make"
"TBLK_TBLK_LINES"
"C"
"9"
"TBLK_TBLK_LINES"
command
"._layer"
"Make"
"TBLK_TBLK_REFTEXT"
"C"
"GREEN"
"TBLK_TBLK_REFTEXT"
command
"._layer"
"Make"
"TBLK_TBLK_REVLINES"
"C"
"9"
command
"._layer"
"Make"
"TBLK_TBLK_REVTEXT"
"C"
"GREEN"
"TBLK_TBLK_REVTEXT"
command
"._layer"
"Make"
"TBLK_TBLK_TEXT"
"C"
"CYAN"
"TBLK_TBLK_TEXT"
command
"._layer"
"Make"
"IPCO"
"C"
"CYAN"
"IPCO"
command
"._layer"
"Make"
"MFG"
"C"
"YELLOW"
"MFG"
command
"._layer"
"Make"
"CLOUD"
"C"
"RED"
"CLOUD"
command
"._layer"
"Filter"
"New"
"Group"
"TBLK_*"
"ATT TBLK Layers"
command
"._layer"
"Filter"
"New"
"Group"
"FiberMgt,IPCO,Line0,Line1,Line2,Line3,Line4,Line5,MFG,Text0,Text1,Text2,Text3,Text4,Text5,Dimen,CLOUD,Image"
"Stations Standard Layers"
command
"._layer"
"Make"
"LINE1"
"color"
"Yellow"
"IPCO"
"LOCK"
"TBLK_BORD_LINES"
"S"
"LINE1"
setvar
'cmdecho
1
princ
Logged
J. Logan
ACAD 2018
I am one with the Force and the Force is with me.
AutoCAD Map 2018 Windows 10
steve.carson
Newt
Re: I'm blind today or something
Reply #1 on:
May 05, 2022, 04:34:25 PM »
Line 11?
Logged
jlogan02
Bull Frog
Reply #2 on:
May 05, 2022, 04:57:36 PM »
Beat me to it!!! I just found it myself. Thanks.
As an aside, in Visual Studio Code, I just discovered you can just put the cursor to the right of an open or left of a closed paren and it will highlight the matching paren.
Logged
J. Logan
ACAD 2018
jlogan02
Bull Frog
Reply #3 on:
May 05, 2022, 04:59:11 PM »
Or left of an open, right of a closed...
Logged
J. Logan
ACAD 2018
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
