Author Topic: Any workaround to add ename keys in filter-list of ssget?  (Read 857 times)
JohnSnow
« on: May 03, 2022, 10:51:38 PM »
After using vlax-ldata method to assign keys to enames. Is there any way to add these these keys in filter-list of ssget OR do I have to ssget all the entities and loop? Is there any workaround to get the entities with the same keys alot quicker like the way ssget with filter-list works instead of looping one by one? Thanks
mhupp
Re: Any workaround to add ename keys in filter-list of ssget?
« Reply #1 on: May 04, 2022, 09:28:08 AM »
I think you want to be using xdata for that. then depending on what 1000's value you are storing you could use that in ssget to filter to those entity's
  1. (setq ss (ssget '((1000 . ""Kenny is great""))))
Tutorial
https://www.afralisp.net/autolisp/tutorials/extended-entity-data-part-1.php
https://www.afralisp.net/autolisp/tutorials/extended-entity-data-part-2.php
JohnSnow
« Reply #2 on: May 05, 2022, 02:57:03 AM »
Tutorial
Thank you.
Does Visual lisp provide similar method to ssget to filter keys in drawing dictionary?
