Author Topic: Alay Text,Mtrext to line  (Read 1086 times)
PM
« on: April 27, 2022, 01:54:01 PM »
Hi i use Tharwat to alay text ,mtext on line. This code at the beginning work only for mtext. I add text and i change acAlignmentTopCenter to acAlignmentMiddleCenter. After this changes text work fine. But when i try to select mtext gives me this error
; error: ActiveX Server returned the error: unknown name: Alignment
I don't know why. Can any one help
  1. (defun c:Atcl (/ l ss i sn v p e)
  2. ;;; Tharwat 31. May. 2012 ;;;
  3.   (if (and (setq l (car (entsel "\n Select Line :")))
  4.            (eq (cdr (assoc 0 (entget l))) "LINE")
  5.            (progn
  6.              (prompt "SelectText,Mtext ")
  7.              (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
  8.            )
  9.       )
  10.     (repeat (setq i (sslength ss))
  11.       (setq sn (ssname ss (setq i (1- i))))
  12.       (setq v (vlax-ename->vla-object sn))
  13.                 l
  14.                 (cdr (assoc 10 (entget sn)))
  15.               )
  16.       )
  17.       (if (eq (cdr (assoc 0 (setq e (entget sn)))) "TEXT,MTEXT")
  18.         (progn
  19.           (entmod (subst (cons 71 5) (assoc 71 e) e))
  20.           (vla-put-insertionpoint v (vlax-3d-point p))
  21.         )
  22.         (progn
  23.          ;(vla-put-alignment v acAlignmentTopCenter)
  24.           (vla-put-alignment v acAlignmentMiddleCenter)
  25.         )
  26.       )
  27.     )
  28.   )
  29.   (princ)
  30. )
  31.
  32.
Re: Alay Text,Mtrext to line
« Reply #1 on: April 27, 2022, 02:32:56 PM »
As the error states alignment is not one of the properties of MTEXT. You will need to check if the item is MTEXT or TEXT then apply the appropriate properties.
Use this to inspect what properties are available.
  1. (if (setq e (car (entsel)))
  2.   (vlax-dump-object (vlax-ename->vla-object e) t)
  3. )
  4. ;; or
  5. (dumpallproperties (car (entsel)))
  6. ;; or
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-A809CD71-4655-44E2-B674-1FE200B9FE30
PM
« Reply #2 on: April 28, 2022, 10:45:03 AM »
I don't know how to fix it.Can any one help?
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: April 28, 2022, 08:11:52 PM »
like this
(setq ent (cdr (assoc 0 (setq e (entget sn)))))
(if (or (eq ent  "TEXT") (eq ent "MTEXT"))
(if (eq ent "TEXT)
          (vla-put-TextAlignmentPoint v (vlax-3D-point p))
       ;  do the mtext stuff here
PM
« Reply #4 on: April 29, 2022, 02:53:25 AM »
Hi BIIGAL. Thanks for the replay. I try your code. Move Text and Mtext on the line but rotate upside down all the Text and i don't know why?
  1.     (defun c:test (/ l ss i sn v p e)
  2.     (vl-load-com)
  3.     ;;; Tharwat 31. May. 2012 ;;;
  4.       (if (and (setq l (car (entsel "\n Select Line :")))
  5.                (eq (cdr (assoc 0 (entget l))) "LINE")
  6.                (progn
  7.                  (prompt "SelectText,Mtext ")
  8.                  (setq ss (ssget "_:L" '((0 . "TEXT,MTEXT"))))
  9.                )
  10.           )
  11.         (repeat (setq i (sslength ss))
  12.           (setq sn (ssname ss (setq i (1- i))))
  13.           (setq v (vlax-ename->vla-object sn))
  14.                     l
  15.                     (cdr (assoc 10 (entget sn)))
  16.                   )
  17.           )
  18.
  19.
  20. (setq ent (cdr (assoc 0 (setq e (entget sn)))))
  21. (if (or (eq ent  "TEXT") (eq ent "MTEXT"))
  22.         (progn
  23.           (entmod (subst (cons 71 5) (assoc 71 e) e))
  24.           (vla-put-insertionpoint v (vlax-3d-point p))
  25.
  26.                 (if (eq ent "TEXT")
  27.         (progn
  28.          ;(vla-put-alignment v acAlignmentTopCenter)
  29.           (vla-put-alignment v acAlignmentMiddleCenter)
  30.         )
  31.         (progn
  32.        ;  do the mtext stuff here
  33.                  (vla-put-alignment v acAlignmentMiddleCenter)
  34.         )
  35.                 )
  36.                 )
  37.       )
  38.
  39.
  40.
  41.         )
  42.       )
  43.       (princ)
  44.     )
  45.
  46.
PM
« Reply #5 on: May 03, 2022, 07:00:01 PM »
Any ideas?
