Author Topic: about foreach  (Read 3683 times)
d2010
Re: about foreach
« Reply #15 on: April 24, 2022, 02:33:07 PM »
I was just trying to show empirical data. I also prefer to use foreach for the reason you stated and the simplicity. never really liked processing selection sets with a counter
You are wrong, the function the "(ssname ss i)" inside C++Arx is very,very fast selection of entities, bettter nth. But in VLISP?
Otherwise the function "(ssnamex SS)" return a+ List, soo, the
(ssnamex SS) is more slowest that  (ssname.i)
 :idea:
  1. (setq i 0)
  2. (if (setq ss (ssget))
  3.   (repeat (sslength ss)
  4.     (setq ent (ssname ss i))
  5.     ... do stuff
  6.     (setq i (1+ i))
  7.   )
  8. )
« Last Edit: April 24, 2022, 02:39:58 PM by d2010 »
mhupp
Re: about foreach
« Reply #16 on: April 24, 2022, 04:06:58 PM »
That's not what i am saying I understand (ssname ss i) is faster, but prefer foreach.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: about foreach
« Reply #17 on: April 24, 2022, 05:50:19 PM »
Over time, I've learned that it's better to spend time writing directly understandable code than to chase hundredths of a millisecond.
Yes ! I agree.
Called Kerry in my other life
I live at UTC + 13.00
kdub_nz
  • SuperMod
Re: about foreach
« Reply #18 on: April 24, 2022, 06:00:00 PM »
Slightly off topic, but . . .
If you can learn from aphorisms ,
From 'The Zen of Python'
Beautiful is better than ugly.
Explicit is better than implicit.
Simple is better than complex.
Complex is better than complicated.
Flat is better than nested.
Sparse is better than dense.
Readability counts.
Special cases aren't special enough to break the rules.
Although practicality beats purity.
Errors should never pass silently.
Unless explicitly silenced.
In the face of ambiguity, refuse the temptation to guess.
There should be one-- and preferably only one --obvious way to do it.
Although that way may not be obvious at first unless you're Dutch.
Now is better than never.
Although never is often better than *right* now.
If the implementation is hard to explain, it's a bad idea.
If the implementation is easy to explain, it may be a good idea.
Namespaces are one honking great idea -- let's do more of those!
I'm also partial to the 'Principle of least astonishment'
« Last Edit: April 24, 2022, 06:06:04 PM by kdub »
d2010
Re: about foreach
« Reply #19 on: April 28, 2022, 01:11:46 AM »
I agree with, kdub. Another great post, baitang36!
thank you
Maybe . the directive "DefMacro", exists inside .Fas?
How to use "DefMacro" inside .Vlx?
kirby
Re: about foreach
« Reply #20 on: April 28, 2022, 11:00:18 AM »
Thanks to all the great minds who weighed in on this.
