Author Topic: number rotate lisp error problem  (Read 1324 times)
dussla
« on: March 31, 2022, 11:54:06 PM »
hi
i made this code
that code is rotate code with  number
but  result is some error
what problem ?
  1. (defun Rtc ( / )
  2.     (setvar "cmdecho" 0)
  3.   (setq osm (getvar "osmode"))
  4.   (prompt "\nRotate Copy or Move")
  5.   (setq ss  (ssget)
  6.         bp  (getpoint "\nCenter point: ")
  7.         tmp 0.0
  8.   )
  9.   (setq angPER (getint (strcat "\n number <" (rtos tmp) ">")))
  10.         (setq ang ( / 360  angPER))
  11.
  12.                 (repeat angPER
  13.
  14.
  15.
  16.
  17.         (command "rotate" ss "" bp ang)
  18.
  19.
  20.                         )
  21.   )
EDIT (John): Added code tags.
« Last Edit: April 01, 2022, 05:56:45 AM by JohnK »
MatGrebe
  • Mosquito
Re: number rotate lisp error problem
« Reply #1 on: April 01, 2022, 03:01:28 AM »
What error do you get ? If you just press Enter (and not type a value) angper will be NIL and then your calculation doesn't work.
Mathias
dussla
« Reply #2 on: April 01, 2022, 05:35:59 AM »
Mathias
Can you see the dwg file?
If you rotate
Does not rotate to the correct angle
For example, if you enter 7
the result is weird
ribarm
  • Marko Ribar, architect
« Reply #3 on: April 01, 2022, 05:58:23 AM »
Mathias
If you rotate
the result is weird
Cnsider using reals instead if integers for calculation!!!
M.R. on Youtube
dussla
« Reply #4 on: April 01, 2022, 10:20:45 AM »
Mathias
If you rotate
the result is weird
Really thank you
Work good
« Reply #5 on: April 04, 2022, 06:00:13 PM »
A few things to consider:
  • Store the value of all system variables before making any changes, and reset them to their original values, rather than assuming that CMDECHO should be set to 1
  • Consider the effect of any active Object Snap modes when supplying the base point to the ROTATE command - you can use the "_non" modifier to ignore all active snaps prior to the point input
  • Consider the possibility that the user may not supply a valid selection, point, or number and use a conditional statement (if/cond) to branch accordingly
  • The value of the 'default' variable tmp will never be assigned to the variable angPer even if the user presses ENTER
  • Consider that the division of two integers will always yield an integer in AutoLISP
  • Use a final (princ) or (prin1) expression as the last expression in the function definition to return a null symbol (i.e. a 'clean' output) to the command line, rather than the value returned by the repeat expression
  • Declare the variables that are local to your function to avoid symbols clashing in the document namespace
« Last Edit: April 04, 2022, 06:09:17 PM by Lee Mac »
