CAD Forums > CAD General
Is anyone here using GstarCAD?
(1/1)
Rustabout:
I used the 2020 version. Saw lots of potential but a few minor to moderate bugs basically barred me from using it for anything profitable. The 2022 version seems a lot better, but still need to test it out a bit more.
It's Alive!:
I’ve tried it from an API perspective. Their GRX implementation is one of the fastest of the clones, but I only tested the things I was working on.
Though the API is not yet complete. I didn’t try lisp. I don’t know how much you rely on apps.
I contacted support and they were responsive.
The GUI looks good. Panning and zooming is fast.
--- Code - C: ---testname ZRX create tin 277.826200testname ZRX create tin 2127.325200 testname GRX create tin 276.886000testname GRX create tin 2035.433400 testname BRX create tin 1245.017900testname BRX create tin 8768.967900 testname GRX create tin undo 255.748200testname GRX create tin undo 1840.230100 testname ZRX create tin undo 409.248100testname ZRX create tin undo 3090.678700 testname BRX create tin undo 1623.380100testname BRX create tin undo 11653.328300
Rustabout:
Thanks for sharing!!
There upgrade is currently on sale. Actually never buy full price as they frequently have sales.
I used it a little more. Still impressed but it does crash often. It crashes noticeably more often than ACAD but not enough to render it un-useable. The CUI is very unstable (as was 2020's).
Some of my LISP that worked in 2020's doesn't work in 2022. Any function that uses the layer object (vla-get-layers) fails; no error just doesn't perform the task. Also, all of my command names using the '`' key (the one to the left of the '1' key) don't work anymore. It's kind of a unique workflow I developed so I might be the only person on earth affected by this :2funny: . I'm more concerned about the vla-get-layers thing because that insinuates that they're messing with the API somehow (not good!!).
With the 2020 support was very responsive at first. I shared my first round of bugs. My second round of bugs... not as responsive... but also they fixed everything I found since then (which was probably a lot of work).
In spite of the above I would probably still pay to upgrade if I wasn't so busy right now. I also need VLIDE. It is very fast and light so I might have another go at it in '23 or '24 though.
Navigation
[0] Message Index
Go to full version
