Author Topic: Can not Attach Mtext to Leader  (Read 386 times)
lethuongtri
  • Mosquito
« on: January 22, 2022, 07:41:17 AM »
Hello everybody . I got a question . So that now I'm creating leader with annotation(Mtext).
The source code is like below .I used "pLeader->attachAnnotation(pMtext->objectID) " but it didn't work.Can you tell me why ?
about Command 's result, I also attached the image below . Please see it.
void
cmdKRLE()
    ads_point pt0,pt1, pt2;
    TCHAR Content[100];
    pt0[0] = 0;
    pt0[1] = 0;
    pt0[2] = 0;
    acedInitGet(1, NULL);
    acedGetPoint(pt0, _T("\n Select the first point:"), pt1);
    acedGetPoint(pt1, _T("\n Select the second point:"), pt2);
    acdbUcs2Wcs(pt1, pt1, false);
    acdbUcs2Wcs(pt2, pt2, false);
    AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
    Acad::ErrorStatus es;
    AcDbBlockTableRecordPointer pBtr(pDb->currentSpaceId(), AcDb::kForWrite);
    if (pBtr.openStatus() != Acad::eOk) return;
    struct resbuf DimScale;
    acedGetVar(_T("DIMSCALE"), &DimScale);
    acedGetString(1, _T("\n Input content:"), Content);
    AcDbObjectPointer <AcDbMText> pMtext;
    pMtext.create();
    pMtext->setContents(Content);
    pMtext->setLayer(_T("TEXT"));
    pMtext->setTextHeight(DimScale.resval.rreal * 3.2);
    pMtext->setLocation(asPnt3d(pt2));
    if (pt2[0] >= pt1[0])
        pMtext->setAttachment(AcDbMText::kBottomLeft);
    else
        pMtext->setAttachment(AcDbMText::kBottomRight);
    es = pBtr->appendAcDbEntity(pMtext);
    if (es != Acad::eOk)
        acutPrintf(_T("\n Can not add Mtext!"));
        return;
    AcDbObjectPointer<AcDbLeader> pLeader;
    pLeader.create();
    pLeader->appendVertex(asPnt3d(pt1));
    pLeader->appendVertex(asPnt3d(pt2));
    es = pBtr->appendAcDbEntity(pLeader);
        acutPrintf(_T("\n Can not add Leader!"));
        return;
    pLeader->setLayer(_T("SCALE"));
    pLeader->setDimscale(DimScale.resval.rreal);
    pLeader->attachAnnotation(pMtext->objectId());
    pLeader->evaluateLeader();
Re: Can not Attach Mtext to Leader
« Reply #1 on: January 22, 2022, 07:13:55 PM »
You should check the error status of every ARX call, likely it will tell when things go bad.
example
Code - C: [Select]
  1.  if (auto e = pMtext->setContents(...); e != eOk)
  2.     acutPrintf(_T("\nError @ pMtext->setContents = %ls: "), acadErrorStatusText(e));
  3.
Also, I like to use set database defaults after creating entities, It might not be the error here, but its the cause of a lot of issues
Code - C: [Select]
  1.         AcDbObjectPointer <AcDbMText> pMtext;
  2.         pMtext.create();
  3.         pMtext->setDatabaseDefaults(pDb);
  4.
Retired
lethuongtri
  • Mosquito
« Reply #2 on: January 22, 2022, 08:42:31 PM »
Thank for your reply . I got this . Let me check my code again with  this.
