Author Topic: Plug-in licensing  (Read 3102 times)
LogicTools
Re: Plug-in licensing
« Reply #15 on: January 14, 2022, 09:03:25 AM »
Thank you guys!!
Since I check up yesterday I've seen that it has been a very lively conversation.
Autodesk has the Entitlement API, which is supercool from a developer’s perspective.
BricsCAD, well I think you need to pre upload keys, so I don’t see how to use hardware info like a MAC address.
Thank you Daniel. I had no idea that the Entitlement API existed!!
For what I read it allows you to also manage a subscription, so I suppose you can publish and let test free for a month and then manage an annual subscription.
Also thanks for your code.
That corroborates my idea of accessing the method with the "WinHttp.WinHttpRequest.5.1" object in lisp.
About the decryptions, absolutely not idea.
Thank you all guys, again.
VovKa
  • Ukraine
« Reply #16 on: January 14, 2022, 03:21:07 PM »
I apologize for my great ignorance,
but ...
how do you calculate this code ?
and then how is it used to decrypt ?
is there no relation to what vl-string-translate does?
it's base64
BIGAL
  • 40 + years of using Autocad
« Reply #17 on: January 14, 2022, 11:16:31 PM »
Just a bit of old fashioned help we had a application with multiple lisps, testing was done un locked so you can use old fashioned DOS bat file to add a users key etc to all files then say make a fas.
copy serial.lsp+lisp1.lsp d:\\Serial\\lisp1.lsp
copy serial.lsp+lisp2.lsp d:\\Serial\\lisp2.lsp
and so on
so the serial.lsp would be edited for each user changing their key. All required files now have the serial key in them.
domenicomaria
« Reply #18 on: January 14, 2022, 11:26:55 PM »
it's base64
yes
i have seen
thank you
baitang36
« Reply #19 on: January 15, 2022, 09:49:36 AM »
and so on
copy /b serial.fas + lisp1.fas d:\\Serial\\lisp1.fas
This is also true
LogicTools
« Reply #20 on: January 15, 2022, 10:19:00 AM »
Thanks BIGAL, baitang36.
That's is a nice strategy to protect lisp files.
In my case I will be using a VLX obviously exposed to bad-cracking as suggested by d2010.
