Author Topic: [challenge] A12 : Replicate the elements of a list a given number of times  (Read 514 times)
Using only AutoLisp, replicate the elements of a list a given number of times.
Example:
(repli '(a b c) 3)
> (A A A B B B C C C)
gile
  • Marseille, France
  1. (defun repli (l n / f)
  2.   (defun f (l i)
  3.     (cond
  4.       ((null l) l)
  5.       ((<= i 0) (f (cdr l) n))
  6.       (T (cons (car l) (f l (1- i))))
  7.     )
  8.   )
  9.   (f l n)
  10. )
_$ (repli '(a b c) 3)
(A A A B B B C C C)
_$ (repli '(a b c) 1)
(A B C)
_$ (repli '(a b c) 0)
nil
_$ (repli '(a b c) -1)
nil
« Last Edit: January 12, 2022, 09:56:15 AM by gile »
bruno_vdh
Hello,
quickly my proposal
(defun repli_vdh (l n / m)
  (apply 'append
(apply 'mapcar
(cons 'list
      (repeat n
(setq m (cons l m))
  1. (defun repli-se7en ( aList quanity / naList)
  2.   (if (zerop quanity)
  3.     aList
  4.     (progn
  5.       (foreach x aList
  6.                (repeat quanity
  7.                        (set 'naList (cons x naList))))
  8.       (reverse naList))) )
  9.
(repli-se7en '(a b c) 3)
> (A A A B B B C C C)
(repli-se7en '(a b c) nil)
> ; error: bad argument type: numberp: nil
(repli-se7en '(a b c) -1)
> nil
(repli-se7en '(a b c) 0)
> (A B C)
Good call on the -1 gile.
mine: if quantity >= 0 return the list. If quantity !number || < 0 return error.
« Last Edit: January 12, 2022, 10:06:54 AM by JohnK »
bruno_vdh
nil
nil[/code]
Ok, corrected version
  (if (> n 0)
    (apply 'append
   (apply 'mapcar
  (cons 'list
(repeat n
  (setq m (cons l m))
gile
  • Marseille, France
IMO, it should return nil when n == 0 (n * 0 = 0)
(A A A B B B C C C)
_$ (repli '(a b c) 2)
(A A B B C C)
(A B C)
nil
Tharwat
  • Hypersensitive
For the sake of unposted way.  :laugh:
  1. (defun Repli-Tharwat ( lst num / new rtn )
  2.   (or (zerop num)
  3.       (foreach itm lst
  4.         (while (not (= (length new) num))
  5.           (setq new (cons itm new))
  6.           )
  7.         (setq rtn (cons new rtn)
  8.               new nil)
  9.         )
  10.       )
  11.   (if rtn (reverse (apply 'append rtn)) lst)
  12.   )
kirby
One more.... with benefit of coming late to the party and catching the problem of nil or negative repetitions
  1. (defun Replicate (MyList NumRep / OutList CNT MyItem1)
  2. ; Challenge A12 : Replicate the elements of a list a specified number of times
  3. ; e.g. (Replicate '(a b c) 3)
  4. ; output (a a a b b b c c c)
  5. (if (or (eq NumRep nil) (< NumRep 0))
  6.         (setq NumRep 0)         ; correct nil or negative reps
  7. )
  8.
  9. (setq OutList nil)
  10.
  11. (if (and MyList (eq (type MyList) 'LIST))
  12.   (progn
  13.         (setq CNT 0)
  14.         (repeat (length MyList)
  15.                 (setq MyItem (nth CNT MyList))
  16.
  17.                 (repeat NumRep
  18.                         (setq OutList (cons MyItem OutList))
  19.                 ) ; close repeat
  20.
  21.                 (setq CNT (1+ CNT))
  22.         ) ; close repeat
  23.
  24.         (setq OutList (reverse OutList))
  25.   )
  26. ) ; close if
  27. OutList
  28. )
  29.
dexus
Here is my version based on the previous challenge.
  1. (defun repli-dexus2 (l x / r i)
  2.   (while l
  3.     (setq i (car l) l (cdr l))
  4.     (repeat x (setq r (cons i r)))
  5.   )
  6.   (reverse r)
  7. )
-1: nil
 0: nil
 1: (A B C)
 2: (A A B B C C)
« Last Edit: January 12, 2022, 11:28:44 AM by dexus »
bruno_vdh
Another...
(defun repli_vdh_2 (l n)
  (if l
    ((lambda (x l)
       (repeat n
(setq l (cons x l))
      (car l)
      (repli_vdh_2 (cdr l) n)
gile
  • Marseille, France
Re: [challenge] A12 : Replicate the elements of a list a given number of times
« Reply #10 on: January 12, 2022, 11:33:35 AM »
Another...
  (if l
    ((lambda (x l)
       (repeat n
(setq l (cons x l))
      (car l)
Pretty one, Bruno !
Stefan
« Reply #11 on: January 12, 2022, 11:53:09 AM »
  1. (defun repli-stef (l n / r)
  2.   (foreach x (reverse l)
  3.     (repeat n
  4.       (setq r (cons x r))
  5.     )
  6.   )
  7. )
gile
  • Marseille, France
« Reply #12 on: January 12, 2022, 12:32:09 PM »
I cannot resist. F# version:
Code - F#: [Select]
  1. let dupli n l =
  2.     [ for x in l do
  3.           for _ in 1 .. n -> x ]
« Last Edit: January 12, 2022, 12:43:16 PM by gile »
bruno_vdh
« Reply #13 on: January 12, 2022, 12:33:05 PM »
Pretty one, Bruno !
Thanks (gile), I had a good master :wink:
« Reply #14 on: January 12, 2022, 02:10:01 PM »
Fixed (I can see that argument):
  2.   (if (not (zerop quanity))
  3.     (progn
  4.       (foreach x aList
  5.                (repeat quanity
  6.                        (set 'naList (cons x naList))))
  7.       (reverse naList))) )
(A A A B B B C C C)
(A A B B C C)
(A B C)
nil
