Author Topic: is it possible to make variable "<" and ">" in a while loop ?  (Read 582 times)
CatDance
« on: January 11, 2022, 01:13:06 AM »
example ..
  1. (defun subr_A ( SignOf<and> angle / )
  2.   (while (SignOf<and>  angle 90)    ;eg (while (< 45 90)
  3.     .... then do stuff
  4.
  5.
  6.   );while
  7. );defun
  8.
SignOf<and> is a var of < or > depending on what I set it before going into this subr to do stuff
Example (Subr_A < 45)
A must-read book: Amazing story how Bill + Paul started Microsoft and history of computer revolution.
https://www.amazon.com/Hard-Drive-Making-Microsoft-Empire/dp/0887306292
Brief history of Microsoft
https://www.youtube.com/watch?v=BLaMbaVT22E
gile
  • Marseille, France
Re: is it possible to make variable "<" and ">" in a while loop ?
« Reply #1 on: January 11, 2022, 02:38:36 AM »
With LISP (as with other functional programming laguages) functions are treated as first-class citizens. That means functions can be used the same way as other data type, e.g. stored in variables, passed as arguments to other functions, returned by functions.
In you case, you can directly pass the < or > operator to the subr_A function:
  1. (subr_A < 45)
or store it in a variable before:
  1. (setq op <)
  2. (subr_A op 45)
But, to be consistent with native higher order functions, you should quote the function passed as argument.
  1. (defun subr_A (SignOf<and> ang)
  2.   (while (apply SignOf<and> (list ang 90))
  4.   )
  5. )
Then you can call it with the quoted operator
  1. (subr_A '< 45)
  1. (setq op '<)
  2. (subr_A op 45)
NOTA: you should not use 'angle' as variable name. It is a protected symbol (native function).
gile
  • Marseille, France
« Reply #2 on: January 11, 2022, 02:43:26 AM »
Another way of defining your 'subr_A' function so that it can accept either quoted or non-quoted operator:
  2.   (setq SignOf<and> (eval SignOf<and>))
  3.   (while (SignOf<and> ang 90)
  4.     .... then do stuff
  5.   )
  6. )
