Author Topic: how to entmod the radius of an Arc ?  (Read 1495 times)
CatDance
« on: January 10, 2022, 02:19:54 AM »
I know how to entmod the start point and end point of an Arc.
But after entmod the arc's points, the radius of the arc also changed ??
A must-read book: Amazing story how Bill + Paul started Microsoft and history of computer revolution.
https://www.amazon.com/Hard-Drive-Making-Microsoft-Empire/dp/0887306292
Brief history of Microsoft
https://www.youtube.com/watch?v=BLaMbaVT22E
Re: how to entmod the radius of an Arc ?
« Reply #1 on: January 10, 2022, 02:50:16 AM »
Do you mean changing the radius without changing the end points?
If the end points can be changed, then simply substitute a new value for group 40 in the DXF data for the ARC entity.
CatDance
« Reply #2 on: January 10, 2022, 05:20:23 AM »
How to find the bulge value if given Arc start point, Arc end point and the Arc radius ?
Is there any Bugle conversion formula ?
HOSNEYALAA
« Reply #3 on: January 10, 2022, 07:26:04 AM »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #4 on: January 10, 2022, 11:35:43 AM »
  1. ;;      arc-radius.lsp
  2. (defun arc-radius (/ GR LST PT)
  3.                   ;|
  4. *****************************************************************************************
  5.
  6. by ElpanovEvgeniy
  7.
  8. Demonstration, educational code
  9. The program allows to choose an arc and dynamically to change its diameter,
  10. Saving an initial and final angle, and centre point.
  11. In the program direct editing DXF of codes of an arc.
  12.
  13. Date of creation   03.22.2005
  14. Last edition       ---
  15.
  16. (arc-radius)
  17. *****************************************************************************************
  18. |;
  19.  (setq lst (entget (car (entsel "\n Select an arc  ")))
  20.        pt  (cdr (assoc 10 lst))
  21.  ) ;_  setq
  22.  (princ "\n Select new radius  ")
  23.  (while (and (setq gr (grread 5)) (= (car gr) 5))
  24.   (entmod (subst (cons 40 (distance pt (cadr gr))) (assoc 40 lst) lst))
  25.   (entupd (cdr (assoc -1 lst)))
  26.  ) ;_  while
  27. ) ;_  defun
  28.
« Reply #5 on: January 10, 2022, 12:09:35 PM »
Great to see you posting here again Evgeniy  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #6 on: January 10, 2022, 12:42:29 PM »
In recent years, I have had little time to write code. I do more management and sometimes train my employees.
Glad to see you in good health!
VovKa
  • Ukraine
« Reply #7 on: January 10, 2022, 03:49:00 PM »
do not forget about us, Евгений
we need some training too ;)
CatDance
« Reply #8 on: January 11, 2022, 01:01:56 AM »
hi
pls see this is
http://www.lee-mac.com/bulgeconversion.html
I can't access LM website on that day I posted this question. Then LM asked me for clarity of my question and I replied. Then on same day I found the formula for finding the bulge of a arc on a forum and get back to "work" on my coding.
Thanks anyway guys.
CatDance
« Reply #9 on: January 11, 2022, 01:02:47 AM »
Thanks Evgeniy and LM
CatDance
« Reply #10 on: January 11, 2022, 01:04:32 AM »
I wonder how CAB is doing ? Where is he now ?
