Author Topic: AutoCAD.SecurityParams how to calculate number for Acadver?  (Read 734 times)
d2010
« on: January 07, 2022, 11:42:20 AM »
Hello
When I execute this command  (setq secPar...) I got the error " Problem in loading application"
Please, how to search name of "AutoCAD.SecurityParams.xx" inside Vlisp?
Can I use (getvar "AcadVer") for replace XX with number
Command: (getvar"Acadver")
"18.0s (LMS Tech)"
(setq secPar
      (vla-GetInterfaceObject
        (vlax-get-acad-object)
        "AutoCAD.SecurityParams.10"))
; error: Automation Error. Problem in loading application
:smitten:
Here is the solution
  1.            (strcat "AutoCAD.SecurityParams." (itoa (atoi (getvar "ACADVER"))))
  2.
« Last Edit: January 07, 2022, 01:13:47 PM by d2010 »
