Author Topic: AutoCAD 2022 - Viewport Reset to Extent  (Read 1323 times)
CMU
  • Mosquito
« on: January 06, 2022, 02:12:04 PM »
May I ask the system variable that controls the viewport always restoring back to extents when clicking model space of an unlocked viewport?
Any help would be appreciated.
Thank you in advance.  :crazy2:
huiz
  • Certified Prof C3D
Re: AutoCAD 2022 - Viewport Reset to Extent
« Reply #1 on: January 06, 2022, 03:14:11 PM »
UCSFOLLOW I think, that must be off.
CMU
  • Mosquito
« Reply #2 on: January 06, 2022, 03:54:16 PM »
Thanks for the tip, but unfortunately 'UCSFOLLOW' was not it.   :-(
I appreciate the help
CMU
  • Mosquito
« Reply #3 on: February 15, 2022, 11:57:41 AM »
For clarification huiz was correct. After much experimentation, the issue was the UCSFollows after all.  Once it is set to 1 and you place your viewports, you will need to set the UCSFollows in each viewport to 0, for it to take effect.  :tickedoff:
Best bet is to set UCSFollows to 0 at start.
Thanks for the help huiz, much appreciated.
CMU
