Author Topic: Get point and object selection at same time  (Read 894 times)
Biscuits
« on: December 28, 2021, 12:10:12 PM »
Stumped on how to change this code to allow me to insert a block then delete the object found at getpoint.
(SETQ PNT (GETPOINT "\nSpecify Insertion Point")) ;;uses nearest osnap
;;;;;;;;;;;; do something here;;;;;;;;;;;;
(COMMAND "ERASE"  previous "")
Appreciate the help.
Tharwat
  • Hypersensitive
Re: Get point and object selection at same time
« Reply #1 on: December 28, 2021, 12:16:16 PM »
  1. (SETQ PNT (GETPOINT "\nSpecify Insertion Point")) ;;uses nearest osnap
  2. (if (setq obj (ssget pnt))
  3.   (command "_.erase" obj "")
  4.   )
  5.
Biscuits
« Reply #2 on: December 29, 2021, 05:49:38 AM »
Thanks ...worked like a charm! I was completely over thinking it.
