Author Topic: x y coordinate of polyline (help with code)  (Read 918 times)
ron345SS
  • Mosquito
« on: December 24, 2021, 01:36:22 PM »
i am trying to modify a running code which prints x and y coordinates of a polyline ..... suppose the x and y coordinate of a poly line is 50 , 40 and the offset  of x is 30 ..... new values to be printed will be 20 , 40 .... i tried to modify the code but i am running into error ... I JUST ADDED ONLY 3 LINES IN RED HIGHLIGHTED
  1. (defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR)
  2.   (setq httt "0.3")
  3.   (setq gptx (getpoint "\nBasepoint for X axis: "))
  4.   (setq gpty (getpoint "\nBasepoint for Y axis: "))
  5.   (setq off (getint "\nX offset: "))
  6.
  7.   (foreach ITEM   NEWVLIST
  8.     (setq XSTR (rtos (nth 0 ITEM) 2 3)
  9.      YSTR (rtos (nth 1 ITEM) 2 3)
  10.      ZSTR (rtos (nth 2 ITEM) 2 3)
  11.      dff  (- (atof xstr) (off)
  12.      STR  (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR) ;_ strcat
  13.     )               ; setq
  14.                ;      (write-line STR F1)
  15.
  16.
  17.
  18.   (command "text"
  19.         (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gptx))
  20.         httt
  21.         "0"
  22.         (strcat  dff)
  23.     )
  24.     (command "text"
  25.         (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gpty))
  26.         httt
  27.         "0"
  28.         (strcat ystr)
  29.     )
the whole working code is
  1. (defun ERR (S)
  2.   (if (= S "Function cancelled")
  3.     (princ "\nVERTEXT - cancelled: ")
  4.     (progn (princ "\nVERTEXT - Error: ") (princ S) (terpri))
  5.   )
  6.   (RESETTING)
  7.   (princ "SYSTEM VARIABLES have been reset\n")
  8.   (princ)
  9. )
  10. (defun SETV (SYSTVAR NEWVAL)
  11.   (setq X (read (strcat SYSTVAR "1")))
  12.   (set X (getvar SYSTVAR))
  13.   (setvar SYSTVAR NEWVAL)
  14. )
  15. (defun SETTING ()
  16.   (setq OERR *ERROR*)
  17.   (setq *ERROR* ERR)
  18.   (SETV "CMDECHO" 0)
  19.   (SETV "BLIPMODE" 0)
  20. )
  21. (defun RSETV (SYSTVAR)
  22.   (setq X (read (strcat SYSTVAR "1")))
  23.   (setvar SYSTVAR (eval X))
  24. )
  25.
  26. (defun RESETTING ()
  27.   (RSETV "CMDECHO")
  28.   (RSETV "BLIPMODE")
  29.   (setq *ERROR* OERR)
  30. )
  31.
  32.
  33. (defun DXF (CODE ENAME) (cdr (assoc CODE (entget ENAME)))) ; dxf
  34.
  35. (defun VERTEXT (/ EN VLIST)
  36.   (setq EN (GET-EN))
  37.   (if (= (DXF 0 EN) "LWPOLYLINE")
  38.     (setq VLIST (GET-LWVLIST EN))
  39.     (setq VLIST (GET-PLVLIST EN))
  40.   )
  41.   (WRITE-IT VLIST EN)
  42. )
  43.
  44. (defun GET-EN (/ NO-ENT EN MSG1 MSG2)
  45.   (setq NO-ENT 1
  46.         EN     NIL
  47.         MSG1   "\nSelect a polyline: "
  48.         MSG2   "\nNo polyline selected, try again."
  49.   )                                     ; setq
  50.   (while NO-ENT
  51.     (setq EN (car (entsel MSG1)))
  52.     (if (and EN
  53.              (or (= (DXF 0 EN) "LWPOLYLINE") (= (DXF 0 EN) "POLYLINE"))
  54.                                         ; or
  55.         )                               ; and
  56.       (progn (setq NO-ENT NIL))         ; progn
  57.       (prompt MSG2)
  58.     )                                   ; if
  59.   )                                     ; while
  60.   EN
  61. )                                       ; get-en
  62.
  63. (defun GET-LWVLIST (EN / ELIST NUM-VERT VLIST)
  64.   (setq ELIST    (entget EN)
  65.         NUM-VERT (cdr (assoc 90 ELIST))
  66.         ELIST    (member (assoc 10 ELIST) ELIST)
  67.         VLIST    NIL
  68.   )                                     ; setq
  69.   (repeat NUM-VERT
  70.     (setq VLIST (append VLIST (list (cdr (assoc 10 ELIST)))) ; append
  71.     )                                   ; setq
  72.     (setq ELIST (cdr ELIST)
  73.           ELIST (member (assoc 10 ELIST) ELIST)
  74.     )                                   ; setq
  75.   )                                     ; repeat
  76.   VLIST
  77. )                                       ; get-lwvlist
  78.
  79. (defun GET-PLVLIST (EN / VLIST)
  80.   (setq VLIST NIL
  81.         EN    (entnext EN)
  82.   )                                     ; setq
  83.   (while (/= "SEQEND" (DXF 0 EN))
  84.     (setq VLIST (append VLIST (list (DXF 10 EN))))
  85.     (setq EN (entnext EN))
  86.   )                                     ; while
  87.   VLIST
  88. )                                       ; get-plvlist
  89.
  90. (defun WRITE-IT (VLST EN / NEWVLIST MSG3 FNAME)
  91.   (setq NEWVLIST (mapcar '(lambda (X) (trans X EN 0)) ;_ lambda
  92.                          VLST
  93.                  ) ;_ mapcar
  94.         MSG3     "Polyline vertex file"
  95.                                         ;FNAME    (getfiled MSG3 "" "txt" 1)
  96.         F1       (open "FNAME" "w")
  97.   )                                     ; setq
  98.   (WRITE-HEADER)
  99.   (WRITE-VERTICES NEWVLIST)
  100.   (setq F1 (close F1))
  101. ) ;_ write-it
  102.
  103. (defun WRITE-HEADER (/ STR)
  104.   (setq STR "        POLYLINE VERTEX POINTS")
  105.   (write-line STR F1)
  106.   (setq STR (strcat "  X            " "  Y            " "  Z") ;_ strcat
  107.   ) ;_ setq
  108.   (write-line STR F1)
  109. ) ;_ write-header
  110.
  111.
  112. (defun WRITE-VERTICES (NEWVLIST / XSTR YSTR ZSTR STR)
  113.   (setq httt "0.15")
  114.   (setq gptx (getpoint "\nBasepoint for X axis: "))
  115.   (setq gpty (getpoint "\nBasepoint for Y axis: "))
  116.
  117.
  118.
  119.
  120.   (foreach ITEM NEWVLIST
  121.     (setq XSTR (rtos (nth 0 ITEM) 2 3)
  122.           YSTR (rtos (nth 1 ITEM) 2 3)
  123.           ZSTR (rtos (nth 2 ITEM) 2 3)
  124.
  125.           STR  (strcat XSTR (SPACES XSTR) YSTR (SPACES YSTR) ZSTR)
  126.                                         ;_ strcat
  127.     )                                   ; setq
  128.                                         ;      (write-line STR F1)
  129.
  130.
  131.
  132.     (command "text"
  133.              (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gptx))
  134.              httt
  135.              "90"
  136.              (strcat xstr)
  137.     )
  138.     (command "text"
  139.              (list (+ (atof xstr) (/ (atof httt) 2.0)) (cadr gpty))
  140.              httt
  141.              "90"
  142.              (strcat ystr)
  143.     )
  144.
  145.   )                                     ; foreach
  146.
  147. )                                       ; write-vertices
  148.
  149.
  150. (defun SPACES (STR / FIELD NUM CHAR SPACE)
  151.   (setq FIELD 15
  152.         NUM   (- FIELD (strlen STR))
  153.         CHAR  " "
  154.         SPACE ""
  155.   ) ;_ setq
  156.   (repeat NUM (setq SPACE (strcat SPACE CHAR))) ;_ repeat
  157. ) ;_ spaces
  158.
  159. (defun C:vv () (SETTING) (VERTEXT) (RESETTING) (princ)) ; c:nsl
EDIT (John): Added code tags and highlights.
« Last Edit: December 24, 2021, 02:00:58 PM by John Kaul (Se7en) »
Re: x y coordinate of polyline (help with code)
« Reply #1 on: December 24, 2021, 02:00:06 PM »
Welcome to the Swamp.
Please take a moment to read up on how to proplerly display your code; this makes it easier for other people to read and thus help you.
https://www.theswamp.org/index.php?topic=48309.0
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: December 24, 2021, 05:27:25 PM »
This may be helpful.
(setq plent (entsel "\nPick rectang"))
(if plent (setq co-ord (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car plent))))))
(princ co-ord)
