Author Topic: System variable  (Read 1180 times)
mohan
System variable
« on: December 22, 2021, 02:40:10 AM »
Pls. help some system variable got changed !  :oops:
When I run this
(defun c:purgeblock ( / )
(repeat 3
(command "_.purge" "_b" "*" "_no")) (princ))
Command: purgeblock
_.purge
Command: _b Unknown command "B".  Press F1 for help.
Command: * Unknown command "*".  Press F1 for help.
Command: _no Unknown command "NO".  Press F1 for help.
Command: _.purge
Command: _.purge
dialogue block displays each time
"Save Energy"
BIGAL
  • 40 + years of using Autocad
Re: System variable
« Reply #1 on: December 22, 2021, 03:24:03 AM »
Try -purge normal purge opens a dcl.
gile
  • Marseille, France
Re: System variable
« Reply #2 on: December 22, 2021, 03:38:30 AM »
@Bigal,
 while called from a (command ...) LISP expression the dialog box is not used except when (initdia) is called before.
@mohan,
try with the complete name of the option.
  1. (defun c:purgeblock ( / )
  2. (command "_.purge" "_blocks" "*" "_no")) (princ))
mohan
Re: System variable
« Reply #3 on: December 22, 2021, 04:01:32 AM »
Command: PURGEBLOCK Unknown command "BLOCKS".  Press F1 for help.
Same error (dialogue block displays each time)
This Error was today from morning
yesterday I was working with script
QAFLAGS 31
_RECOVER "D:\Drawings\Hospital\BP2# Civil Package - 1\Landscape\L-100.dwg" _.qsave _.close
_RECOVER "D:\Drawings\Hospital\BP2# Civil Package - 1\Landscape\L-101.dwg" _.qsave _.close
_RECOVER "D:\Drawings\Hospital\BP2# Civil Package - 1\Landscape\L-301.dwg" _.qsave _.close
_RECOVER "D:\Drawings\Hospital\BP2# Civil Package - 1\Landscape\L-401+2+3.dwg" _.qsave _.close
_RECOVER "D:\Drawings\Hospital\BP2# Civil Package - 1\Landscape\L-410.dwg" _.qsave _.close
QAFLAGS 16
QUIT
;;End Script
;;End Script
Then one lisp I loaded
(defun c:rcdir ( / pth filelst)
(setq pth (getstring "\nType path where are *.dwg files to recover <ex. c:/.../.../> : "))
(setq filelst (vl-directory-files pth "*.dwg"))
(foreach file filelst (command "recoverall" (strcat pth file)))
(princ))
« Last Edit: December 22, 2021, 04:08:53 AM by mohan »
"Save Energy"
gile
  • Marseille, France
Re: System variable
« Reply #4 on: December 22, 2021, 04:47:33 AM »
So, I was wrong about dialog box. @BIGAL was right.
Try this way:
  1. (defun c:purgeblock ()
  2.   (repeat 3
  3.     (command "_.-purge" "_blocks" "*" "_no")) (princ))
mohan
Re: System variable
« Reply #5 on: December 22, 2021, 06:57:53 AM »
Try this way:
  2.   (repeat 3
Yes, this was working, but do I have to update all my lisps . . .
"Save Energy"
mohan
Re: System variable
« Reply #6 on: January 03, 2022, 02:10:17 AM »
Hi Guys
The issue is this system variable got changed - QAFLAGS 31
Now all my previous lisps work fine.
"Save Energy"
