(defun MsgBox(Msg Buttons DefBt Title / FP CANCEL DEFBT1 DEFBT2 DEFBT3 DEFBTC DEFBTN DEFBTY FL FP HEIGHT I I-J ID J NO STD WIDTH YES ~CANCEL ~NO ~YES )
(setq ~yes nil ~no nil ~cancel nil)
(cond ((wcmatch buttons "*OK*") (setq yes "OK" ~yes "确定"))
((wcmatch buttons "*Yes*") (setq yes "Yes" ~yes "是"))
(if (wcmatch buttons "*No*") (setq no "No" ~no "否"))
(if (wcmatch buttons "*Cancel*") (setq cancel "Cancel" ~cancel "取消"))
(setq DefBtY "" DefBtN "" DefBtC "")
(cond ((= DefBt "Yes") (setq DefBtY "is_default=true;"))
((= DefBt "No") (setq DefBtN "is_default=true;"))
((= DefBt "Cancel") (setq DefBtC "is_default=true;"))
(setq Msg (strcat "\n" Msg "\n\n"))
(setq i -1 height 0 width 0)
(while (setq i (vl-string-search "\n" Msg (1+ (setq j i))))
(if (> (setq i-j (- i j)) 50) (setq height (+ height 1 (fix (/ i-j 50.0)))))
(setq width (max width (- i j)) height (1+ height))
(setq fp (vl-filename-mktemp "~HGCAD.dcl"))
(if (not (setq fl (open fp "w")))(exit))
(write-line (strcat "MsgBox:dialog{label=" title "; :column{") fl)
(write-line (strcat ":row{spacer_1;:text_part{key=\"msg\";width=" (itoa (min width 50)) ";height=" (itoa height) ";}}") fl)
(write-line ":row{spacer_1;" fl)
(if ~yes (write-line (strcat ":cancel_button{label=" ~yes ";key=\"yes\";width=10;" DefBtY "}") fl))
(if ~no (write-line (strcat ":cancel_button{label=" ~no ";key=\"no\";width=10;" DefBtN "}") fl))
(if ~cancel (write-line (strcat ":cancel_button{label=" ~cancel ";key=\"cancel\";width=10;" DefBtC "}") fl) )
(write-line "spacer_1;}}}" fl)
(close fl)
(setq std 0 id (load_dialog fp))
(new_dialog "MsgBox" id)
(set_tile "msg" msg)
(if ~yes (action_tile "yes" "(done_dialog 1)"))
(if ~no (action_tile "no" "(done_dialog 2)"))
(if ~cancel (action_tile "cancel" "(done_dialog 3)"))
(setq std (start_dialog))
(unload_dialog id)
(vl-file-delete fp)
(cond ((= std 1) yes)
((= std 2) no)
((= std 3) cancel)
; 消息,输入框默认值,标题
(defun EditBox(Msg Edit Title / FL FP ID RTEDIT STD )
(setq Msg (strcat " " Msg " "))
(write-line (strcat "EditBox:dialog{label=" title "; initial_focus = \"edit\";:column{") fl)
(write-line (strcat "spacer_1;:text_part{key=\"msg\";width=" (itoa (strlen msg)) ";}") fl)
(write-line ":edit_box {key=\"edit\";}" fl)
(write-line ":row{spacer_1;}" fl)
(write-line ":cancel_button{label=\"确定\";key=\"OK\";width=8;is_default=true;}" fl)
(write-line "spacer_1; :cancel_button{label=\"取消\";key=\"cancel\";width=8;}" fl)
(close fl)
(new_dialog "EditBox" id)
(set_tile "msg" Msg)
(set_tile "edit" Edit)
(action_tile "OK" "(setq Rtedit (get_tile \"edit\"))(done_dialog 1)")
(action_tile "cancel" "(done_dialog 2)")
(unload_dialog id)
(vl-file-delete fp)
(cond ((= std 1) Rtedit)
((= std 2) "")
(defun C:n ()
(setq ret (MsgBox "是否继续操作?" "YesNo" "No" "提示"))
(setq ret (EditBox "请输入数值" "123" "输入"))
