Author Topic: Trim outside closed polyline  (Read 1413 times)
sigster
« on: December 20, 2021, 04:22:54 PM »
Hi
I run into this sample and was try to use polyline not curve but nothing happened
https://forums.autodesk.com/t5/net/how-to-trim-the-culve-outside-the-polyline/m-p/7705850?profile.language=en
      Private Function GetClipBoundary(ByVal ed As Editor) As ObjectId
            Dim peo = New PromptEntityOptions(vbLf & "Select boundary Polyline: ")
            peo.SetRejectMessage(vbLf & "Requires a closed, Polyline")
            peo.AddAllowedClass(GetType(Polyline), False)
            peo.AllowObjectOnLockedLayer = True
            peo.AllowNone = True
            Dim per = ed.GetEntity(peo)
            If per.Status <> PromptStatus.OK Then Return ObjectId.Null
            Using tr = New OpenCloseTransaction()
                Try
                    Dim Lina As Polyline = CType(tr.GetObject(per.ObjectId, OpenMode.ForRead), Polyline)
                    If Not (Lina.Closed AndAlso Lina.IsPlanar) Then
                        ed.WriteMessage(vbLf & "Invalid selection, requires a closed, planar curve 2222.")
                    End If
                    Return per.ObjectId
                Finally
                    tr.Commit()
                End Try
            End Using
        End Function
        Private Function GetObjectsToClip(ByVal ed As Editor) As SelectionSet
            Dim pso As PromptSelectionOptions = New PromptSelectionOptions()
            pso.RejectObjectsFromNonCurrentSpace = True
            pso.RejectObjectsOnLockedLayers = True
            Dim filter = New SelectionFilter({New TypedValue(0, "LINE,ARC,CIRCLE,SPLINE,LWPOLYLINE,ELLIPSE,INSERT,MTEXT,TEXT,POINT")})
            Dim psr = ed.GetSelection(pso, filter)
            Return If(psr.Status = PromptStatus.OK, psr.Value, Nothing)
        End Function
        <CommandMethod("CUTOUTSIDE")>
        Sub ClipObjectsCommand2()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim db As Database = doc.Database
            Dim boundaryId As ObjectId = GetClipBoundary(ed)
            If boundaryId.IsNull Then Return
            Dim selection As SelectionSet = GetObjectsToClip(ed)
            If selection Is Nothing Then Return
            Try
                Using tr As Transaction = doc.TransactionManager.StartTransaction()
                    Dim boundary As Polyline = CType(tr.GetObject(boundaryId, OpenMode.ForRead), Polyline)
                    Dim btr = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                    For Each id As ObjectId In selection.GetObjectIds()
                        If id <> boundaryId Then
                            Using trimmer As Autodesk.AutoCAD.ExportLayout.Trimmer = New Autodesk.AutoCAD.ExportLayout.Trimmer()
                                Dim entityToTrim As Entity = CType(tr.GetObject(id, OpenMode.ForWrite), Entity)
                                trimmer.Trim(entityToTrim, boundary)
                                If trimmer.HasAccurateResults Then
                                    For Each ent As Entity In trimmer.TrimResultObjects
                                        ent.SetPropertiesFrom(entityToTrim)
                                        btr.AppendEntity(ent)
                                        tr.AddNewlyCreatedDBObject(ent, True)
                                    Next
                                    If trimmer.EntityCompletelyOutside OrElse trimmer.EntityOnBoundary Then entityToTrim.[Erase]()
                                End If
                            End Using
                        End If
                    Next
                    tr.Commit()
                End Using
            Catch ex As System.Exception
                ed.WriteMessage(vbLf & "Operation failed ({0})", ex.Message)
            End Try
        End Sub
