Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Load or Code Issue? Invoking Lisp from Command Line
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Load or Code Issue? Invoking Lisp from Command Line (Read 757 times)
Chillme1
Newt
Must learn to earn!
on:
December 20, 2021, 10:31:27 AM »
Before a needed back-to-basics LISP learning series, I ask:
What is needed to make this borrowed lisp routine run?
After ensuring the attached lisp file routine is in the SFSP and the loading it (load "deletelayerstate"), AutoCAD proudly announces that the LOAD failed.
Code - Auto/Visual Lisp:
[Select]
defun
c:deletelayerstate
lsp pat s
setvar
"cmdecho"
0
if
setq
lst
a
layerstatelist
progn
foreach
s lst
princ
strcat
\n
s
;foreach
textscr
setq
pat
getstring
\n
Type name or patern of layerstates to delete: "
command
"_-Layer"
"_State"
foreach
s lst
if
wcmatch
s pat
progn
beep
command
"_delete"
s
princ
strcat
\n
s
" - deleted"
;progn
;if
;foreach
command
;progn
;if
princ
;defun
Logged
Thanks, Clint
Mechanical Designer / Process Piping
AutoCAD Toolsets 2022
Newbie Betimes - LISP Programmer
Administrator
Seagull
Re: Load or Code Issue? Invoking Lisp from Command Line
Reply #1 on:
December 20, 2021, 10:51:31 AM »
You need to find the following functions (and load those at the same time as this one):
(a+laterstatelist)
(beep)
Logged
TheSwamp.org
(serving the CAD community since 2003)
Chillme1
Newt
Must learn to earn!
Reply #2 on:
December 20, 2021, 02:42:19 PM »
Ah-ha! Delving into web history...!
Thanks,
Logged
Thanks, Clint
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
