Author Topic: Right-Click Settings  (Read 7180 times)
chilldaddy
« on: December 16, 2021, 08:37:51 AM »
When it comes to right-click actions, my preference is to show the shortcut menu. When setting OPTIONS in a main competitor, a dialog box makes setting this action more visual and intuitive.
From "competitor's" HELP:
Shortcut Menu: Enabled When Command Options Are Present
Enables the Command shortcut menu only when command options are available at the Command prompt. If no options are available, a right-click is the same as pressing Enter.
I found the bit-based setting selections/combinations to be cumbersome related to the variable SHORTCUTMENU setting.
Your thoughts on SHORTCUTMENU preferences and/or on the lack of a more dialog-based settings interface are welcome. :-D
danAllen
Re: Right-Click Settings
« Reply #1 on: December 16, 2021, 10:30:42 AM »
This is my settings on v15. For me the lack of dialogs for settings is worth the reduced cost of Bricscad.
Chillme1
  • Must learn to earn!
« Reply #2 on: December 20, 2021, 04:48:11 PM »
I thank you for your input, danAllen!
Thanks, Clint
Mechanical Designer / Process Piping
AutoCAD Toolsets 2022
Newbie Betimes - LISP Programmer
