Author Topic: Polyline Direction  (Read 1883 times)
PM
Polyline Direction
« on: December 12, 2021, 03:28:13 AM »
Hi . I am using this code to find the direction of the polyline. If the polyline is clockwise show red arrows unless show green arrows. Is it posssible only in case we have the red arrows to reverse the direction of the polyline?
  1.
  2. (defun c:pld (/ *error* VxV clockwise-p acDoc ms ss i e j p a c h s f r d)
  3.         ms (if
  4.                (eq (getvar 'cvport) 1)
  5.                (vla-get-paperspace acDoc)
  6.                (vla-get-modelspace acDoc)
  7.                )
  8.   )
  9.
  10.   (defun *error* (m)
  11.     (and m (not (wcmatch (strcase m) "*CANCEL*,*EXIT*,*QUIT*")) (princ (strcat "\nError: " m)))
  12.     (vla-endundomark acDoc)
  13.     (princ)
  14.     )
  15.
  16.   (defun VxV (a b)
  17.     (list (- (* (cadr a) (caddr b)) (* (caddr a) (cadr b)))
  18.           (- (* (caddr a) (car b)) (* (car a) (caddr b)))
  19.           (- (* (car a) (cadr b)) (* (cadr a) (car b)))
  20.     )
  21.   )
  22.   ;(clockwise-p ename)                         ;
  23.   ;argument:                                   ;
  24.   ;   e - ename of curve                       ;
  25.   ;       closed 2D curve in WCS               ;
  26.   ;return: T for clockwise curve               ;
  27.   ;----the pacman shape (and probably more)    ;
  28.   ;    doesn't work in acad2011                ;
  29.   ;A curve has the same orientation as an      ;
  30.   ;infinitesimal segment positioned around its ;
  31.   ;minima or maxima                            ;
  32.   ;Stefan M. 11.11.2013                        ;
  33.   (defun clockwise-p (e / p1 p2 p a b d f1 f2)
  34.     (vla-getboundingbox (vlax-ename->vla-object e) 'p1 'p2)
  35.       (mapcar '- (vlax-safearray->list p1) '(1 1 0))
  36.       '(1 0 0)
  37.    )
  38. )
  39.           a  (vlax-curve-getstartparam e)
  40.           b  (vlax-curve-getendparam e)
  41.           d  (if
  42.                (eq (cdr (assoc 0 (entget e))) "SPLINE")
  43.                 (* 0.01 (- b a))
  44.                 0.1
  45.              )
  46.           f1 (vlax-curve-getfirstderiv e (+ a (rem (+ p d) (- b a))))
  47.           f2 (vlax-curve-getfirstderiv e (+ a (rem (+ (- p d) (- b a)) (- b a))))
  48.     )
  49.     (minusp (caddr (VxV f2 f1)))
  50.   )
  51.   ;selfinters[ecting object]                   ;
  52.   ;argument:                                   ;
  53.   ;   o - vla-object                           ;
  54.   ;       CLOSED 2D curve in WCS               ;
  55.   ;return: T for selfintersecting curve        ;
  56.   ;Stefan M. 11.11.2013                        ;
  57.   (defun selfinters (o / a)
  58.     (or
  59.         (setq a (vl-catch-all-apply 'vlax-invoke (list ms 'addregion (list o))))
  60.       )
  61.       (vla-delete (car a))
  62.       )
  63.     )
  64.
  65.
  66.   (if
  67.     (setq ss (ssget '((0 . "*POLYLINE,SPLINE,LINE"))))
  68.      (progn
  69.        (setq h (* 0.05 (getvar 'viewsize)))
  70.        (repeat (setq i (sslength ss))
  71.          (setq e (ssname ss (setq i (1- i)))
  72.                c (cond ((and                         ;arrows color
  73.                           (vlax-curve-isplanar e)
  74.                           (vlax-curve-isclosed e)
  75.                           (not (selfinters (vlax-ename->vla-object e)))
  76.                         )
  77.                         (if (clockwise-p e) 1 3)     ;green if clocwise, red if not
  78.                        )
  79.                        ((if (< (car (vlax-curve-getstartpoint e)) (car (vlax-curve-getendpoint e))) 1 3))
  80.                        )
  81.                )
  82.          (if
  83.            (eq (cdr (assoc 0 (entget e))) "SPLINE")
  84.            (setq s (vlax-curve-getstartparam e)      ;start curve
  85.                  f (vlax-curve-getendparam e)
  86.                  j 10                     ;10 arrows on a single spline
  87.                  d (/ (- f s) j)                     ;segment "length" (in paramter units)
  88.                  )
  89.            (setq s 0.0
  90.                  j (fix (vlax-curve-getendparam e))  ;1 arrow per segment for polylines
  91.                  d 1.0
  92.                  )
  93.            )
  94.          (repeat j
  95.            (setq j (1- j)
  96.                  r (+ s (* j d) (* 0.5 d))           ;current parameter
  97.                  p (vlax-curve-getpointatparam e r)
  98.                  a ((lambda (d) (atan (cadr d) (car d))) (vlax-curve-getfirstderiv e r))
  99.            )
  100.            (grdraw p (polar p (+ a (* pi 0.9)) h) c)
  101.            (grdraw p (polar p (- a (* pi 0.9)) h) c)
  102.          )
  103.        )
  104.      )
  105.   )
  106.
  107.   (vla-endundomark acDoc)
  108.   (princ)
  109. )
  110.
  111.
  112.
zak26
Re: Polyline Direction
« Reply #2 on: December 12, 2021, 09:44:30 AM »
What I usually do to reverse a polyline direction is the following, hope it helps
(vl-cmdf "_.pedit" e "_r" "")
PM
« Reply #3 on: December 12, 2021, 11:18:50 AM »
 Hi zak26 and mhupp. I know the reverse command ,but i don't know how to write
if is red then reverse the polyline. In this way i skip to go to modify menu to reverse it
mhupp
« Reply #4 on: December 12, 2021, 01:57:46 PM »
Read the notes in the lisp.
  1.   ;(clockwise-p ename)                         ;
  2.   ;argument:                                   ;
  3.   ;   e - ename of curve                       ;
  4.   ;       closed 2D curve in WCS               ;
  5.   ;return: T for clockwise curve               ;
line 83  (if (clockwise-p e) 1 3)     ;green if clocwise, red if not
Maybe run this before the other code or at the start.
  1. ;;----------------------------------------------------------------------------;;
  2. ;; Flips Backwards ploylines
  3. (defun C:SWAP (/ SS)
  4.   (setq SS (ssget "_X" '((210 0.0 0.0 -1.0))))
  5.   (if (/= SS nil)
  6.     (progn
  7.       (prompt (strcat "\nEntities Swapped: " (itoa (sslength SS))))
  8.       (vl-cmdf "_.Mirror3d" SS "" "xy" "0,0,0" "y")
  9.     )
  10.     (prompt "\nNothing to Swap!")
  11.   )
  12.   (princ)
  13. )
« Last Edit: December 12, 2021, 02:02:55 PM by mhupp »
PM
« Reply #5 on: December 12, 2021, 03:38:16 PM »
Thanks mhupp
BIGAL
  • 40 + years of using Autocad
« Reply #6 on: December 12, 2021, 05:03:03 PM »
Just a side note Autocad has "Reverse" as a command but Bricscad does not so what about a Line ?
(defun c:rt ( / oldsnap pt1 pt2 obj ana)
(setq oldsnap (getvar 'osmode))
  (setvar "osmode" 0)
  (while
    (setq ss (ssget "+.E:S:" (list (cons 0 "*line"))))
    (if (= ss nil)
      (alert "You have not picked \nPline or \nLine")
       (setq obj (vlax-ename->vla-object (ssname ss 0)))
       (if (= (vla-get-ObjectName obj) "AcDbLine")
         (vlax-put-property obj 'startpoint pt2)
         (vlax-put-property obj 'endpoint pt1)
        (command "pedit" (ssname ss 0) "R" "")
  (setvar "osmode" oldsnap)
PM
« Reply #7 on: December 12, 2021, 05:42:52 PM »
Nobody understand what i ask for.  I ask to include the autocad reverse command in the code of the first post .If the arrows is red then reverse the polyline.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: December 12, 2021, 07:17:31 PM »
Maybe check the vertex segments, if more are clockwise,
if the cross product of AB and AC are co-directional to the normal of the plane, then it should be clockwise.
I have no idea how to do this in lisp  :mrgreen:
mhupp
« Reply #9 on: December 12, 2021, 08:04:12 PM »
Update line 83 of your original code
zak26
« Reply #10 on: December 13, 2021, 09:29:50 AM »
Just as Mhupp just said it's easy, you just have to do this
(defun c:pld2 (/ *error* VxV clockwise-p acDoc ms ss i e j p a c h s f r d)
  (setq acDoc (vla-get-activedocument (vlax-get-acad-object))
        ms (if
  (vla-startundomark acDoc)
  (defun *error* (m)
  (defun VxV (a b)
  ;argument:                                   ;
  ;minima or maxima                            ;
    (setq p  (vlax-curve-getparamatpoint e
   (vlax-curve-getclosestpointtoprojection e
      '(1 0 0)
          d  (if
                (* 0.01 (- b a))
                0.1
  ;argument:                                   ;
  ;   o - vla-object                           ;
    (or
      (vl-catch-all-error-p
         (if (= c 1)
        (setq c 3)
           (setq s 0.0
                 d 1.0
         (repeat j
           (setq j (1- j)
Now you won't see the Red arrows, and all of your polylines will be counter clockwise, you should try to modify your lisps.
And the command is now pld2
« Last Edit: December 13, 2021, 09:34:03 AM by zak26 »
mhupp
« Reply #11 on: December 13, 2021, 11:14:01 AM »
Nice Zak26 but was thinking more of a one line edit.
(if (clockwise-p e) (vl-cmdf "_.pedit" e "_r" ""))
before
zak26
« Reply #12 on: December 14, 2021, 09:37:15 AM »
before
I was thinking something similar but in that line c is been setup, so you can't do something like that and also if you do that you leave c without a value so becomes an error
mhupp
« Reply #13 on: December 14, 2021, 12:12:28 PM »
  6.                )
  7.                (if (clockwise-p e) (vl-cmdf "_.pedit" e "_r" ""))
  8.                (if (clockwise-p e) 1 3)     ;green if clocwise, red if not  ;it will always be 3 now maybe just change to (setq c 3)?
  9.               )
  10.               ((if (< (car (vlax-curve-getstartpoint e)) (car (vlax-curve-getendpoint e))) 1 3))
  11.         )
  12. )
What I was talking about. I need to be more articulate when posting.
Should have said add this line instead of edit
