Author Topic: PDFattach command makes drawing too slow  (Read 1274 times)
Coder
« on: December 11, 2021, 06:44:32 AM »
« Last Edit: December 11, 2021, 02:38:41 PM by Coder »
d2010
Re: PDFattach command makes drawing too slow
« Reply #1 on: December 11, 2021, 06:50:36 AM »
You try Linux PDF-Viewer.inside Linux. iso
If PDFReader.rpm do not have the problem with Zoomin, then yourWin10Pc have a big-problem.
« Reply #2 on: December 12, 2021, 01:45:50 PM »
What is this?
mhupp
« Reply #3 on: December 12, 2021, 04:49:50 PM »
Coder originally posted that if they imported a PDF into the drawing everything ran slow after that. before changing to ......................................................................
You could convert the PDF into tiff usually they are less system dependent.
« Reply #4 on: December 12, 2021, 05:03:41 PM »
Of course the drawing will run slow. PDFs are just a container for many different types of stuff (images, postscripts, etc) there could be all sorts of thigs inside that PDF that are slowing down AutoCAD.
I second mhupp's suggestion.
I'm not sure how the WSL will help AutoCAD in this case, d2010. I mean as far as I know, AutoCAD itself is reading the PDF contents; it doesn't use a system viewer does it?
Rod
« Reply #5 on: December 12, 2021, 08:46:38 PM »
Change pdfosnap sysvar 0, seems to help
"All models are wrong, some models are useful" - George Box
cmwade77
« Reply #6 on: December 23, 2021, 03:00:01 PM »
What version of AutoCAD? This has become less of an issue over the years, I think AutoCAD 2019 or 2020 was the first version where this sped up dramatically, 2021 and 2022 further improved speed.
