CAD Forums > CAD General
[rant] What happened to AutoCAD
JohnK:
I took a job that made me switch back to using AutoCAD--instead of Revit--after years away. The last AutoCAD I used was about 2012. I used a few versions here and there but it was mostly for construction admin or answering RFIs (-i.e. nothing close to full time use).
1. What happened to block insert? I'm trying to get use to this "library interface" but this is ridiculous. I believe CAB had a block program so if I find a good routine, I'll modify this post.
2. The ribbon is very cumbersome to use (and takes up too much real estate) . Made the switch back to using old menus and toolbars already.
3. So far I have a love/hate relationship with multileaders.
Rob...:
Don't get caught going down the rabbit hole trying to set it up like you remember. Much better off putting that time into learning the new interface.
framednlv:
Ribbon, I hate the way it changes when you select xrefs or different types of entities.
Block insertion, create new Tool Palettes
Multileaders, I've got them using custom lisp:
kdub_nz:
--- Quote from: John Kaul (Se7en) on November 30, 2021, 03:49:02 PM ---
1. What happened to block insert? >>>>
--- End quote ---
I use CLASSICINSERT . . . changed the .PGP
I"ve been dragged out of retirement . . . first thing I complained about too :)
It's Alive!:
Hate the ribbon :crazy2:
when I was drafting I used cleanscreen and autohotkey to customize my num pad for command shortcuts.
Navigation
[0] Message Index
[#] Next page
Go to full version
