(defun c:blockfind ( / ss )(vl-some '(lambda (layout)(if (setq ss (ssget "X" (list (cons 2 "A$C1A300073") (cons 67 1) (cons 410 layout))))(list ss layout)))(layoutlist)) (princ))
It's likely easier to approach it this way:
Your codes search only in Paper spaces so you need to bring the result from the vl-some function out to publicity to know the outcome.
