Author Topic: Changing Fonts  (Read 3230 times)
danAllen
Re: Changing Fonts
« Reply #15 on: November 29, 2021, 05:49:03 PM »
EDIT: It appears the correct font is getting used, it just displays wrong in the User Interface elements, such as the Style dialog and the ribbon when editing text.
Is this true after saving & reopening the drawing?
Alternately I wonder if you ran through the -STYLE command, entering "" to accept current settings, would that trigger a refresh of a style displaying incorrectly?
cmwade77
Re: Changing Fonts
« Reply #16 on: November 29, 2021, 05:50:04 PM »
I believe that I have found a solution that works in AutoCAD as well as BricsCAD, please see attached. It turned out, AutoCAD also needs SetFont.
Edit: Updated again due to a typo.
« Last Edit: November 29, 2021, 05:59:00 PM by cmwade77 »
cmwade77
Re: Changing Fonts
« Reply #17 on: November 29, 2021, 05:51:20 PM »
Yes, it is true after saving and reopening, I finally found where the issue was in AutoCAD, BricsCAD was more robust at handling the change than AutoCAD was, AutoCAD needed to use vla-setfont.
