Author Topic: About exit and quit functions  (Read 1211 times)
baitang36
« on: November 06, 2021, 06:39:42 AM »
A friend asked, what is the difference between exit and quit? Can the information it displays be changed?
Let's do an experiment and enter it on the command line! Exit enter
command:!exit
#<SUBR @0d6753c0 QUIT>
Enter on the command line !Quit enter
Command:! quit
It is found that the displayed content is exactly the same, that is, exit is only an alias of quit, and there is no difference in function.
At the command line, enter (exit)
command: (exit)
; Error: quit / exit abort
The string "quit / exit abort" is too obvious. You can see that exit is called at a glance. Can you change it?
According to this information # < subr @ 0d6753c0 quit >, we found its address in the memory, and found its hometown through this address. The starting address is 3344h in the file vlaflb.fsl, and its program code (hexadecimal) is as follows:
14 01 00 00 01 ; Function start
09 B4 02 ;  string "vlmsg. DLL"
33 20 35 00 00 ; Integer 13600
51 02 B3 02 01 00 ; Call the function string resource
51 01 E2 02 01 00 ; Call function_ msg-err
16 ; End of function
; 2b4 vlmsg.dll
; 2b3 string-resource
; 2e2 _ msg-err
 decompile into source code is:
(defun quit()
( _msg-err( string-resource "vlmsg.dll" 13600 ))
It calls an unpublished reservation function _msg-err to exit and display information.
Because the reserved function can only be used in Fas and not in LSP, I made an  exit.fas and defined a function exit-msg to customize the exit information.
After loading, you can call the function exit-msg
Usage: (exit-msg  string)
For example (exit-msg "incorrect registration code!")
An unpublished reservation function was also found _Exit-process is used to exit acad.exe and directly return to the operating system.
Usage: (exit-process integer)
For example (exit-process 123)
This usage will exit the program directly and the unsaved diagram will be lost.
If you need exit.fas, please email me 5520971@qq.com
print1985
  • Mosquito
Re: About exit and quit functions
« Reply #1 on: January 03, 2022, 08:53:30 AM »
Thank you very good
danAllen
« Reply #2 on: January 03, 2022, 01:04:36 PM »
why not define your own *error* function and output a different message?
see http://www.lee-mac.com/errorhandling.html
