Author Topic: Convert COGO point label to MLEADERs  (Read 4669 times)
CHulse
« on: November 05, 2021, 03:50:03 PM »
Does anyone by chance know of a way or tool to convert C3D cogo point labels to MLEADER representations?
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
huiz
  • Certified Prof C3D
Re: Convert COGO point label to MLEADERs
« Reply #1 on: November 06, 2021, 04:44:56 PM »
Dynamo?
alanjt
  • Standby for witty remark...
« Reply #2 on: January 26, 2022, 01:22:11 PM »
To what end?
If you double explode your points, you'll get a node, leader (if point was in dragstate), and mtext label.
I assume you don't care the labels are no longer dynamic to the actual point data?
Dropbox
CHulse
« Reply #3 on: February 02, 2022, 09:39:07 AM »
I can't take credit for this since all I really did was cobble together code from other folks, but it definitely solved my issue.
I did want to try to maintain the labels to be as usable as possible for the client who is not using C3D, so MLEADER entities seemed to be the best option. And this doesn't destroy the COGOs, so I can just hide them for the client.
It uses this:
https://forums.autodesk.com/t5/civil-3d-customization/how-to-see-if-a-point-label-has-been-moved-to-dragged-state/m-p/9660859/highlight/true#M18406
« Last Edit: February 02, 2022, 09:42:46 AM by CHulse »
Cary Hulse
