Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
problem with mirrtext in net autocad c sharp
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: problem with mirrtext in net autocad c sharp (Read 1747 times)
daboho
Newt
on:
October 30, 2021, 04:20:07 PM »
i am using code to mirroring dimension but text is become reverse how to text not to reverse
see picture
i dont want text to mirroring
Logged
n.yuan
Bull Frog
Re: problem with mirrtext in net autocad c sharp
Reply #1 on:
November 01, 2021, 09:44:56 AM »
The discussion here would be helpful:
https://forums.autodesk.com/t5/net/entity-mirror/m-p/9596451
Logged
daboho
Newt
Reply #2 on:
November 01, 2021, 10:45:49 AM »
Thank very match,but its has solved by me
Logged
gile
Gator
Marseille, France
WWW
Reply #3 on:
November 02, 2021, 02:26:36 AM »
Using the COM Mirror method as suggested by Alexander Rivilis in the topic Norman Yuan linked seems to work fine.
Code - C#:
[Select]
CommandMethod
"MIRRORDIM"
public
static
void
MirrorDim
var
doc
Application
DocumentManager
MdiActiveDocument
var
db
doc
Database
var
ed
doc
Editor
var
peo
new
PromptEntityOptions
\n
Select dimension: "
peo
SetRejectMessage
\n
Selected object is not a dimension."
peo
AddAllowedClass
typeof
Dimension
false
var
per
ed
GetEntity
peo
if
per
Status
PromptStatus
OK
return
var
ppo
new
PromptPointOptions
\n
First point: "
var
ppr
ed
GetPoint
ppo
if
ppr
Status
PromptStatus
OK
return
var
pt1
ppr
Value
TransformBy
ed
CurrentUserCoordinateSystem
ppo
Message
\n
Second point: "
ppo
BasePoint
ppr
Value
ppo
UseBasePoint
true
ppr
ed
GetPoint
ppo
if
ppr
Status
PromptStatus
OK
return
var
pt2
ppr
Value
TransformBy
ed
using
var
tr
db
TransactionManager
StartTransaction
var
dim
Dimension
tr
GetObject
per
ObjectId
, OpenMode
ForRead
dynamic
acadDim
dim
AcadObject
acadDim
Mirror
pt1
ToArray
, pt2
ToArray
tr
Commit
Logged
daboho
Newt
Reply #4 on:
November 13, 2021, 10:11:22 AM »
thanks gile
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
