Author Topic: Having problem with class inhetitage  (Read 1155 times)
ekoneo
« on: October 19, 2021, 03:33:28 AM »
I created a Form1 form including a label1. Also I created a class1 file. When Form1 load the startFunction methos will be triggered by the Form1_Load event. startFunction is a inherited method.
namespace MyNameSpace
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load (object sender, EventArgs e)
            StartMethod();
        public void startMethod()
            Class1 ClasInherited = new Class1();
            ClasInherited.ChangeLabelText();
Class1.cs file include ChangeLabelText() method.
public partial class Class1
    Form1 form1 = new YuzeyAnaliz();
     public void ChangeLabelText()
     form1.label5.Text = "Text changed";
However label5 text doesnt change. I am missing something.
« Last Edit: October 19, 2021, 03:37:46 AM by ekoneo »
MickD
Re: Having problem with class inhetitage
« Reply #1 on: October 19, 2021, 04:39:36 PM »
You are 'embedding' another form inside the Class1 class, not inheriting Class1
Form1 inherits from Form
Class1 doesn't inherit anything but it does create a Form1 inside itself (encapsulation)
Something like this should work:
Code - C#: [Select]
  1.     public class Form1 : Form
  2.     {
  3.         public Form1() // constructor, you can initialize everything here instead of _Load if you want
  4.         {
  5.             InitializeComponent();
  6.             // you can change text here too
  7.         }
  8.
  9.         private void Form1_Load(object sender, EventArgs e)
  10.         {
  11.             // _Load good for loading external data say or saved settings when the form is loaded
  12.             StartMethod();
  13.
  14.             // or just change text here, no need for StartMethod():
  15.             // this.lable5.Text = "Text changed";
  16.         }
  17.
  18.         public void StartMethod()
  19.         {
  20.             this.lable5.Text = "Text changed";
  21.         }
  22.     }
  23.
- John Carmack
- J.R.R. Tolkien
