CAD Forums > Vertically Challenged
Find pipe structure in plan from profile view
(1/1)
entget:
I have a pipe structure in profile I want to reference to a different surface ...by selecting the structure in profile, selecting the desired surface in profile - instead of select structure, right click, structure properties, reference surface, pick ellipsis, pick other surface, select ok, select ok
...what I think I need to do is select the structure in profile, get the source objects name and change the surface there (the 'plan' view of it)
I am stuck after selecting the profile structure - is the GetModelNetworkPart method what I need? ...or am I chasing the unobtainable?
Thanks!
Jeff_M:
Yes, that is the method to use.
BlackBox:
--- Code - Lisp: ---(vl-load-com) (defun c:SsPartsInPlan (/ *error* parts ss) (defun *error* (msg) (if ss (vla-delete ss)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (ssget "_:L" '((0 . "AECC_GRAPH_PROFILE_NETWORK_PART"))) (progn (setq parts (ssadd)) (vlax-for x (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object) ) ) ) (setq parts (ssadd (vlax-vla-object->ename (vlax-invoke x 'getmodelnetworkpart) ) parts ) ) ) (sssetfirst nil parts) ) ) (*error* nil))
entget:
thank you both! ...it seems the more i program, the fewer the resources or examples are available for what i'm after - appreciate the help very much!! the swamp never fails!!
Navigation
[0] Message Index
Go to full version
