Author Topic: How to replacing the content of a text by the point of indicated point ?  (Read 1623 times)
PM
Hi .I am searching for a lisp to replacing the content of a text by the point of indicated point. This will work for longsections and cross secrions.
« Last Edit: September 30, 2021, 05:13:24 AM by PM »
PM
Re: How to replacing the content of a text by the point of indicated point ?
« Reply #1 on: September 30, 2021, 10:04:39 AM »
Any options?
PM
« Reply #2 on: October 02, 2021, 05:17:01 AM »
Any ideas ?
« Reply #3 on: October 03, 2021, 12:06:57 AM »
My Idea. Get Civil3D.  :wink:
HOSNEYALAA
Re: Help with a lisp
« Reply #4 on: October 03, 2021, 06:17:51 AM »
Hi, why did you use the LISP?
It gives correct values at first
And an error in the other values at the end
or
You can adjust it manually
It should be modified in the LISP
you bankrupt Him and you lockdown the forum.swamp.lisp.
E.g for this topic, the title of Topic
How to replacing the content of a text by the point of indicated point?
BIGAL
  • 40 + years of using Autocad
« Reply #5 on: October 04, 2021, 03:28:53 AM »
The lisp Surface RL comes to mind does what you want, pick datum text pick datum line, enter vertical scale, pick point, then text, pick point then text and so on.
Available for a small fee. Or write one based on what I have provided. Like Ronjonp idea.
didier
  • expatrié
« Reply #6 on: October 07, 2021, 06:02:47 AM »
Bonjour PM
I would like to know how you draw these profiles, do you have a lisp that does it or do you start civil3d ?
To answer your question it would be useful to have a drawing extract to understand your data it will only work punctually, click on the point, click on the text...
A small lsp will do the job
Amicalement
eternal beginner ...
my english is not fluent ...
PM
« Reply #7 on: October 07, 2021, 11:36:40 AM »
I draw them manually in autocad. I don't have any other software because i don't need it every day.
BIGAL
« Reply #8 on: October 07, 2021, 08:53:10 PM »
You ask all the time and never have a go at writing a solution.
I have what you want and know it works used it for years.
The manual version with calculator, is get datum, compare dist 2 points, / scale factor, add datum this is text value.
didier
  • expatrié
« Reply #9 on: October 08, 2021, 11:58:58 AM »
Bonjour PM
I don’t see the example drawing, we can’t help you. Sorry
