Author Topic: Change input language to English if any other language  (Read 2905 times)
HasanCAD
« on: September 21, 2021, 08:25:35 PM »
Hi All
My native language is not English, So is there a way to switch input language to English when switch to AutoCAD?
Edit:
While I am using AutoCAD I have to switch to Word or chat (for example)  and typing in my native language (Arabic)
Then switch back to AutoCAD and commands in AutoCAD should be in English.
That what I am asking about, Is there a way to switch the language to English when switch to AutoCAD?
« Last Edit: September 26, 2021, 02:09:01 PM by HasanCAD »
BIGAL
  • 40 + years of using Autocad
Re: Change input language to English if any other language
« Reply #1 on: September 21, 2021, 09:59:25 PM »
One way is to make all your clauses as English and other language then would do a if Eng use clause22 its a bit messy but not sure how to do otherwise I would have a Library lisp that has all the clauses in it and autoload, then just need some form of global setting eng or xxx.  Can use get, setenv to set language. There may be a defun sort of answer like (setq ent (doents)) (setq ss (doss))
(setq g22 "\nWählen Sie pline")
(setq e22 "\nSelect Pline ")
(setq lang "eng")
(defun doents ( )
(if (= "eng" lang)
(princ (entsel e22))
(princ (entsel g22))
« Last Edit: September 21, 2021, 10:07:15 PM by BIGAL »
HasanCAD
« Reply #2 on: September 22, 2021, 03:23:02 AM »
(setq lang "eng")
(defun doents ( )
(if (= "eng" lang)
My native language is Arabic. So
you want me to call the command in English when type the same leter in Arabic
  1. (setq م (c:line))
It this what you want me to do?
Crank
« Reply #4 on: September 25, 2021, 01:21:30 PM »
Just install the language pack to run AutoCAD in your preferred language.
HasanCAD
« Reply #5 on: September 25, 2021, 04:39:23 PM »
Sorry for that but my native language (Arabic) is not listed.
Crank
« Reply #6 on: September 26, 2021, 02:59:19 AM »
There has never been an Arabic language pack.
In the OP you asked for English, so I was thinking you've to install that version.
HasanCAD
« Reply #7 on: September 26, 2021, 10:35:28 AM »
Some times while I am using AutoCAD I have to switch to Word or chat (for example)  and typing in my native language (Arabic)
Then switch back to AutoCAD and In AutoCAD should be in English
Crank
« Reply #8 on: September 26, 2021, 06:03:02 PM »
What you can try:
[CTRL + SHIFT] switches the keyboard layout.
[ALT(left) + SHIFT] to change the input language.
If that doesn't work, go to your Control Panel -> Regional and Language Options -> Languages tab -> Keyboard > details
There, you can edit the hotkeys to change input languages and you will be able to change (disable) the hotkey which switches keyboard layouts.
It's even possible to have different settings for your applications.
