Author Topic: Protect Lisp Using Motherboard Serial key  (Read 2634 times)
sandunmadushan
  • Mosquito
« on: September 14, 2021, 02:59:47 AM »
Hello. i have this lisp for protect lisp by using motherboard serial  key. but have some issue with that. if any one can fix that code.
thank you.
VovKa
  • Ukraine
Re: Protect Lisp Using Motherboard Serial key
« Reply #1 on: September 14, 2021, 08:43:13 AM »
it is not clear what are you to trying to protect
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: September 14, 2021, 10:50:08 PM »
I have used this with multiple lisps in old days with protect you now use FAS. It is a simple method of having your getserialnumber and a variable with that number in a small lisp
(defun MAINBOARDSERIAL ( /  ITEM METH1 METH2 S SERX WMI) ;MOTHER BORD
(VL-LOAD-COM )
(setq WMI (vlax-create-object "WbemScripting.SWbemLocator"))
(setq METH1 (vlax-invoke WMI 'CONNECTSERVER NIL NIL NIL NIL NIL NIL NIL NIL))
(setq METH2 (vlax-invoke METH1 'EXECQUERY "select SerialNumber from Win32_BaseBoard"))
(setq S
                     (vlax-for ITEM METH2
                        (setq SERX (LIST (vlax-get ITEM 'SERIALNUMBER)))
(vlax-release-object METH1)
(vlax-release-object METH2)
(vlax-release-object WMI)
(if (= "123456789" s)
(princ "all ok")
(alert "Incorrect serial number please contact Santa Clause for correct number\n will now exit)")(EXIT)
Ok now for the smart part and you have to be old and know dos you can do the following at cmd line
COPY PROTECT.lsp+mylisp1.lsp C:\newlisps\Mylisp1.lsp
so this will add the protect.lsp at the start of the code, then do a lisp compile to FAS.
You can batch run all your lisps
COPY PROTECT.lsp+mylisp2.lsp C:\newlisps\Mylisp2.lsp
COPY PROTECT.lsp+mylisp3.lsp C:\newlisps\Mylisp3.lsp
(VL-LOAD-COM)
(setq loads (list "Lisp1" "Lisp2" "Lisp3"))
(setq loc1 "F:\\") ;;change dirs to where ever you want them saved
(setq loc2 "F:\\Compiled Lisp\\")
(foreach lisp loads
(vlisp-compile 'st (strcat loc1 lisp ".lsp") (strcat loc2 lisp ".fas"))
d2010
« Reply #3 on: September 22, 2021, 04:02:23 AM »
First problem----- You must export all TEXTs, to external file (hanssan.lng), from Lisp2Lng
Full-automatically
001="\nEnd"
002="SNAPANG"
003="\nFirst point of polyline: "
004="\nNext point of polyline"
005="\nEnter nextangle [11.25/22.5/45.0/60.0/90.0/eXit/Red/Magenta/Plinedo]"
006="\nGet-Default.Angle="
007="\n[Clockwise/Anti-clockwise/Viewctr?"
008="USERR1"
009="(1)"
010="ORTHOMODE"
011="[012469XRYMP]"
012="[126]"
013="[CA]"
014=")="
015="[YN]"
016="\nBold.Shx[Yes/No/About]?"
017="STR"
018="REAL"
019="LUPREC"
020="a207errorB<>Str"
021="a207errorA "
022=">:"
023="SETVAR"
024="GETVAR"
025="\nT469error<>Str:"
026="VIEWCTR"
You convert (jc_lda18 to C# and DLL.
You encrypte all indexOf-Texts
--(e.g38=indexofText @jc_cws12 38 24)
--(e.g05-IndexOfText @jc_cws12 05 7)
 and call-names with two-serial- number (e.g. CPuid+hdd) you wtil got TopEncryptor+serial.
(Defun nn_vmload( / $rr p_n p_o dyn ang dma lhz ana lpt clock ppo idx item points ogg old love lpt ppt)
 (setq;|a000=I extract all TEXT-s to "pp_cadaschtroumpf_makepline_.ini"|;
ogg (jc_cws12 5 7)
dma (list (jc_cws12 12 27) (jc_cws12 38 24) (jc_cws12 61 70) (jc_cws12 130 20) (jc_cws12 149 36))) (jc_lda18 "24D7" (list 8)) (setq;|a000|;
ana (jc_lda18 "40FE" (list (nth 3 dma) (jc_lda18 "4E37" (list (jc_cws12 184 6)))))) (jc_lda18 "24D7" (list 8)) (setq;|a000|;
p_o (jc_lda18 "A3DF" (list (nth 0 dma)))) (jc_lda18 "24D7" (list 8)) (setq;|a000|;
p_n (jc_lda18 "A3DF" (list p_o (strcat (nth 1 dma) (jc_cws12 190 3))))) (setq;|a000|;
ang (jc_lda18 "EC47" (list p_o p_n))) (setq;|a000|;
lhz (list ana 11.25 22.5 "3" 45.0 "5" 60.0 "7" "8" 90.0)) (setq;|a000|;
love (list ogg (jc_cws12 193 9) (jc_cws12 185 6))
Bold.Shx (jc_lda18 "8C77" (list love (list ang 1 ana)))) (jc_lda18 "898A" (list)) (setq;|a000|;
lpt (list p_n p_o)) (setq;|a000|;
ppo p_n) (setq;|a000|;
dyn "0") (progn (setq;|a000|;
idx 2) (while (/= dyn "X") (progn  (jc_lda18 "5D0D" (list lpt 1)) (setq;|a000|;
clock "") (setq;|a000|;
dyn (jc_lda18 "E6D1" (list (jc_cws12 202 13) (nth 2 dma)))) (if (=  dyn "0") (setq;|a000|;
ang (jc_lda18 "4E37" (list (jc_cws12 185 6)))) (if (=  dyn "1") (setq;|a000|;
ang (nth 1 lhz)))) (if (=  dyn "2") (setq;|a000|;
ang (nth 2 lhz))) (if (=  dyn "4") (setq;|a000|;
ang (nth 4 lhz))) (if (=  dyn "6") (setq;|a000|;
ang (nth 6 lhz))) (if (=  dyn "9") (setq;|a000|;
ang (nth 9 lhz))) (if (=  dyn "R") (jc_lda18 "5D0D" (list lpt "1")) (if (=  dyn "M") (jc_lda18 "5D0D" (list lpt "6")) (if (=  dyn "P") (jc_lda18 "C4A3" (list lpt)) (setq;|a000|;
clock (if (jc_lda18 "46CA" (list dyn (jc_cws12 215 5))) (jc_lda18 "E6D1" (list (jc_cws12 220 4) (nth 4 dma))) "0"))))) (if (/= clock "0") (progn  (if (=  clock "C") (setq;|a000|;
ang (/ (* ang pi) 180.0)) (if (=  clock "A") (setq;|a000|;
ang (/ (* ang (- 0 pi)) 180.0)))))) (jc_lda18 "1C2B" (list (jc_cws12 6 7) (+ (jc_lda18 "4E37" (list (jc_cws12 6 7))) ang))) (setq;|a000|;
ppt (jc_lda18 "A3DF" (list ppo (strcat (jc_lda18 "B118" (list dma)) "(" (itoa idx) (jc_cws12 224 2))))) (setq;|a000|;
lpt (if ppt (jc_lda18 "4DFA" (list ppt lpt)) lpt)
idx (+ idx (if ppt 1 0))) (setq;|a000|;
ppo (if ppt ppt ppo))))) (setq;|a000|;
dyn (jc_lda18 "E6D1" (list (jc_cws12 226 4) (jc_cws12 230 25)))) (if (=  dyn "Y") (jc_lda18 "8C77" (list love Bold.Shx)) (if (=  dyn "A") (jc_lda18 "6E00" (list readme.txtr))))
$rr)
  1. (Defun nn_vmload( / $rr p_n p_o dyn ang dma lhz ana lpt clock ppo idx item points ogg old love lpt ppt)
  2.  (setq;|a000=You see same defun in NativeLanguage in VLISP|;
  3.          ogg "SNAPANG"
  4.          dma (list "\nFirst point of polyline: " "\nNext point of polyline" "\nEnter nextangle [11.25/22.5/45.0/60.0/90.0/eXit/Red/Magenta/Plinedo]" "\nGet-Default.Angle=" "\n[Clockwise/Anti-clockwise/Viewctr?")) (initget 8) (setq;|a000|;
  5.          ana (dfn_getx_real (nth 3 dma) (getvar "USERR1"))) (initget 8) (setq;|a000|;
  6.          p_o (getpoint (nth 0 dma))) (initget 8) (setq;|a000|;
  7.          p_n (getpoint p_o (strcat (nth 1 dma) "(1)"))) (setq;|a000|;
  8.          ang (angle p_o p_n)) (setq;|a000|;
  9.          lhz (list ana 11.25 22.5 "3" 45.0 "5" 60.0 "7" "8" 90.0)) (setq;|a000|;
  10.          love (list ogg "ORTHOMODE" "USERR1")
  11.          Bold.Shx (syst_mapvars love (list ang 1 ana))) (vl_load_com) (setq;|a000|;
  12.          lpt (list p_n p_o)) (setq;|a000|;
  13.          ppo p_n) (setq;|a000|;
  14.          dyn "0") (progn (setq;|a000|;
  15.          idx 2) (while (/= dyn "X") (progn  (dfn_grdraw_listpoint lpt 1) (setq;|a000|;
  16.          clock "") (setq;|a000|;
  17.          dyn (dfn_getx_readkey "[012469XRYMP]" (nth 2 dma))) (if (=  dyn "0") (setq;|a000|;
  18.          ang (getvar "USERR1")) (if (=  dyn "1") (setq;|a000|;
  19.          ang (nth 1 lhz)))) (if (=  dyn "2") (setq;|a000|;
  20.          ang (nth 2 lhz))) (if (=  dyn "4") (setq;|a000|;
  21.          ang (nth 4 lhz))) (if (=  dyn "6") (setq;|a000|;
  22.          ang (nth 6 lhz))) (if (=  dyn "9") (setq;|a000|;
  23.          ang (nth 9 lhz))) (if (=  dyn "R") (dfn_grdraw_listpoint lpt "1") (if (=  dyn "M") (dfn_grdraw_listpoint lpt "6") (if (=  dyn "P") (nn_vmcall lpt) (setq;|a000|;
  24.          clock (if (wcmatch dyn "[126]") (dfn_getx_readkey "[CA]" (nth 4 dma)) "0"))))) (if (/= clock "0") (progn  (if (=  clock "C") (setq;|a000|;
  25.          ang (/ (* ang pi) 180.0)) (if (=  clock "A") (setq;|a000|;
  26.          ang (/ (* ang (- 0 pi)) 180.0)))))) (setvar "SNAPANG" (+ (getvar "SNAPANG") ang)) (setq;|a000|;
  27.          ppt (getpoint ppo (strcat (cadr dma) "(" (itoa idx) ")="))) (setq;|a000|;
  28.          lpt (if ppt (cons ppt lpt) lpt)
  29.          idx (+ idx (if ppt 1 0))) (setq;|a000|;
  30.          ppo (if ppt ppt ppo))))) (setq;|a000|;
  31.          dyn (dfn_getx_readkey "[YN]" "\nBold.Shx[Yes/No/About]?")) (if (=  dyn "Y") (syst_mapvars love Bold.Shx) (if (=  dyn "A") (alert readme.txtr)))
  32. $rr)
  33.
You insert any SErial (cpu, motherboard) ininside(jc_ldc31 "0x24D7") .
Code - Text: [Select]
  2.  (setq;|a000=You see encrypted DefunNames but with all TEXT-s|;
  3.          ogg "SNAPANG"
  4.          dma (list "\nFirst point of polyline: " "\nNext point of polyline" "\nEnter nextangle [11.25/22.5/45.0/60.0/90.0/eXit/Red/Magenta/Plinedo]" "\nGet-Default.Angle=" "\n[Clockwise/Anti-clockwise/Viewctr?")) (jc_ldc31 "0x24D7:C001" (list 8) (setq;|a000|;
  5.          ana (jc_ldc31 "0x40FE:C002" (list (nth 3 dma) (jc_ldc31 "0x4E37:C003" (list "USERR1"))) (jc_ldc31 "0x24D7:C004" (list 8) (setq;|a000|;
  6.          p_o (jc_ldc31 "0xA3DF:C005" (list (nth 0 dma))) (jc_ldc31 "0x24D7:C006" (list 8) (setq;|a000|;
  7.          p_n (jc_ldc31 "0xA3DF:C007" (list p_o (strcat (nth 1 dma) "(1)"))) (setq;|a000|;
  8.          ang (jc_ldc31 "0xEC47:C008" (list p_o p_n)) (setq;|a000|;
  11.          Bold.Shx (jc_ldc31 "0x8C77:C009" (list love (list ang 1 ana))) (jc_ldc31 "0x898A:C010" (list) (setq;|a000|;
  15.          idx 2) (while (/= dyn "X") (progn  (jc_ldc31 "0x5D0D:C011" (list lpt 1) (setq;|a000|;
  17.          dyn (jc_ldc31 "0xE6D1:C012" (list "[012469XRYMP]" (nth 2 dma))) (if (=  dyn "0") (setq;|a000|;
  18.          ang (jc_ldc31 "0x4E37:C013" (list "USERR1")) (if (=  dyn "1") (setq;|a000|;
  23.          ang (nth 9 lhz))) (if (=  dyn "R") (jc_ldc31 "0x5D0D:C014" (list lpt "1") (if (=  dyn "M") (jc_ldc31 "0x5D0D:C015" (list lpt "6") (if (=  dyn "P") (jc_ldc31 "0xC4A3:C016" (list lpt) (setq;|a000|;
  24.          clock (if (jc_ldc31 "0x46CA:C017" (list dyn "[126]") (jc_ldc31 "0xE6D1:C018" (list "[CA]" (nth 4 dma)) "0"))))) (if (/= clock "0") (progn  (if (=  clock "C") (setq;|a000|;
  26.          ang (/ (* ang (- 0 pi)) 180.0)))))) (jc_ldc31 "0x1C2B:C019" (list "SNAPANG" (+ (jc_ldc31 "0x4E37:C020" (list "SNAPANG") ang)) (setq;|a000|;
  27.          ppt (jc_ldc31 "0xA3DF:C021" (list ppo (strcat (jc_ldc31 "0xB118:C022" (list dma) "(" (itoa idx) ")="))) (setq;|a000|;
  28.          lpt (if ppt (jc_ldc31 "0x4DFA:C023" (list ppt lpt) lpt)
  31.          dyn (jc_ldc31 "0xE6D1:C024" (list "[YN]" "\nBold.Shx[Yes/No/About]?")) (if (=  dyn "Y") (jc_ldc31 "0x8C77:C025" (list love Bold.Shx) (if (=  dyn "A") (jc_ldc31 "0x6E00:C026" (list readme.txtr)))
  32. $rr)
  33.
  1. #region
  2. nn_vmload
  3.
  4. (defun nn_vmload( / rip $ef $ef $l1 $l3 ac1 ac2 espilon exx loopde nop ada pde ele elc elf ac3 blc cc1 cc3 cec stc)
  5. /*c2s:
  6.        cec=0,
  7.        cc1=1,
  8.        cc3=3,
  9.        dyn="CICLERAD",
  10.        epsilon=dfn_getx_real("\nGet EpsiLon=",getvar(dyn)),
  11.        epsilon=abs(epsilon),
  12.        epison=(epsilon<0.003)?0.780209:epsilon;
  13.        for(ac1=getvar("VIEWCTR");dyn!="N";cec=1-cec)
  14.           { $eg=nil,
  15.             stc=nil,
  16.             nop=nil,
  17.             ac2=nil,
  18.             $l1=0,
  19.             $l3=0,
  20.             ac1=getpoint("\ngetStartPoint:");
  21.             if (ac1==nil)
  22.                 loopde=dfn_ssg_tolistvla(ssget("X")),
  23.                 nop=foreach(pde,car(loopde),vla.put_color(pde,7)),
  24.                 nop=vla.Regen(con_acdoc,acAllViewports);
  25.               else ac2=getpoint(ac1,"\ngetEndPoint:");
  26.             if (ac1!=nil)
  27.                  $ef=dfn_ssgx_blockeatpoint("LINE",10,epsilon,ac1),
  28.                  $l1=dfn_ssg_len($ef);
  29.             if (ac2!=nil)
  30.                       $eg=dfn_ssgx_blockeatpoint("LINE",11,epsilon,ac2),
  31.                       $l3=dfn_ssg_len($eg);
  32.             if (acor(ac1,ac2))
  33.                 { stc=str_princ(list("\n$l1=[",$l1,"]\t$l3=[",$l3,"]"));
  34.                   cc1=(cec==1)?1:3;
  35.                   cc3=(cec==1)?3:1;
  36.                 };
  37.            if ($l3>0)
  38.                 loopde=dfn_ssg_tolistvla($eg),
  39.                 nop=foreach(pde,car(loopde),vla.put_color(pde,cc3));
  40.            if ($l1>0)
  41.                loopde=dfn_ssg_tolistvla($ef),
  42.                nop=foreach(pde,car(loopde),vla.put_color(pde,cc1));
  43.            if (acor($l1>0,$l3>0))
  44.                 vla.Regen(con_acdoc,acAllViewports);
  45.             dyn=dfn_getx_readkey("[YNC]","\nContinue?(y.yes)(n.noexit): "),
  46.             dyn=(dyn=="C")?"Y":dyn;
  47.           };
  48. */
  49. nil)
  50. %include=dfn_ssgx_blockeatpoint
  51. %include=dfn_getx_real
  52. %include=dfn_ssg_tolistvla
  53. %include=dfn_getx_readkey
  54. %include=if_pointdwg
  55. %include=dfn_ssg_len
  56. %include=str_princ
  57. #endregion
  58.
« Last Edit: October 01, 2021, 02:33:43 PM by d2010 »
