Author Topic: Getfiled dialog box problem  (Read 1430 times)
CatDance
« on: September 13, 2021, 02:12:03 AM »
when dialog box is called using below ...
  1. (setq pGDF (getfiled "Select a TRS file to Load A Saved Game" n/Path "txt" 8))
  2.
  3.
(1)  How to make it stay focus in the folder (of filenames) and NOT at the key-in of filename.
Becos when I click a file (other than the 1st filename) it always display the 1st filename at the key-in filename box.
A must-read book: Amazing story how Bill + Paul started Microsoft and history of computer revolution.
https://www.amazon.com/Hard-Drive-Making-Microsoft-Empire/dp/0887306292
Brief history of Microsoft
https://www.youtube.com/watch?v=BLaMbaVT22E
tombu
  • ByLayer=>Not0
Re: Getfiled dialog box problem
« Reply #1 on: September 13, 2021, 10:06:13 AM »
Why is it displaying "lsp" files when "txt" was specified as the extension?
Tom Beauford P.S.M.
Crank
« Reply #2 on: September 13, 2021, 01:20:18 PM »
This is a bug that exists since Windows7. You can use DosLib in stead:
(dos_getfiled "Select a TRS file to Load A Saved Game" n/Path "Saved game files (*.txt)|*.txt")or:
(dos_getfilenav "Select a TRS file to Load A Saved Game" n/Path "txt" 8)
CatDance
« Reply #3 on: September 13, 2021, 03:48:11 PM »
just an example to show where the focus area
CatDance
« Reply #4 on: September 13, 2021, 03:51:13 PM »
I try to write a dialog box for the getfiled.
I have not written a line of lisp for about 7 years. Now my head is almost empty (forgotten most of it). Have a difficult time writing dialog box now.
