Author Topic: Modifying a Field to become a formula for a label  (Read 2749 times)
MSTG007
« on: September 09, 2021, 04:54:25 PM »
Gotta question, I stumbled upon Mr Rons Area Field routine. how would I modify the field value to become a formula?
I want to create a formula which would take the value,
i.e. (((([Area Field]+[Calculated Area Field])/2)*4)/43560)
Taking the selected polyline, offsetting it 12' inside and using that value. (Not sure how to make that happen. lol.)
Thanks for any direction!
(strcat
      "%<\\AcObjProp Object(%<\\_ObjId "
      (if (> (vl-string-search "x64" (getvar 'platform)) 0)
(vlax-invoke-method
  (cond (oUtil)
((setq oUtil (vla-get-utility acDoc)))
  'getobjectidstring
  x
  :vlax-False
(rtos (vla-get-objectid x) 2 0)
      ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%" ;; I think this is the area to modify
(defun c:FOO (/ *error* acDoc oSpace origin insertionPoint oUtil oMText)
  (defun *error* (msg)
    (if acDoc
      (vla-endundomark acDoc)
    (cond ((not msg)) ; Normal exit
  ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit)
  ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it
  (if (ssget "_:L" '((0 . "CIRCLE,*POLYLINE")))
      (vla-startundomark
(setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
      (setq oSpace
     (vlax-get
acDoc
(if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)
      (setq origin (vlax-3d-point '(0 0 0)))
      (vlax-for x (vla-get-activeselectionset acDoc)
;; Calculate the centroid
(vla-getboundingbox x 'mn 'mx)
(setq insertionPoint
       (vlax-3d-point
(mapcar '*
(mapcar '+
(vlax-safearray->list mn)
(vlax-safearray->list mx)
'(0.5 0.5 0.5)
;; Add mtext
(setq oMText
  (vla-addmtext
    oSpace
    origin
    0.0
    (strcat
(vlax-invoke-method
  (cond (oUtil)
  'getobjectidstring
  x
  :vlax-False
(vla-put-attachmentpoint oMText acmiddlecenter)
(vla-move oMText origin insertionPoint)
;;<-- Set MText height, style, etc. here... Example:
(vla-put-height oMText (/ 1. (getvar 'cannoscalevalue)))
;; ... others.
  (*error* nil)
Civil3D 2020
Re: Modifying a Field to become a formula for a label
« Reply #1 on: September 09, 2021, 05:49:25 PM »
You can create a formula using the field command to decipher the syntax needed:
%<\AcExpr ((%<\_FldPtr 2465500283456>%+%<\_FldPtr 2465500283968>%/2)*4/43560) \f "%lu2">%
« Reply #2 on: September 09, 2021, 09:52:42 PM »
I'm posting a link to SMadsen's "Room Area lisp"; it doesn't use fields but it's just a simple attribute block tied to a pline's handle. Very nice routine.
https://www.theswamp.org/index.php?topic=32060.msg375362#msg375362
MSTG007
« Reply #3 on: September 10, 2021, 12:08:13 PM »
I was able to figure the top part out.
;;       "%<\\AcObjProp Object(%<\\_ObjId "
              "%<\\AcExpr %<\\AcObjProp Object(%<\\_ObjId "
I know what the FLDPTR is supposed to do, but not sure how to get that to work in this scenario.
;; Add mtext
(setq oMText
  (vla-addmtext
    oSpace
    origin
    0.0
    (strcat
(vlax-invoke-method
  (cond (oUtil)
  'getobjectidstring
  x
  :vlax-False
;;       ">%).Area \\f \"%pr2%lu2%ct4%qf1 SQ. FT.\">%"
;;             %<\AcExpr ((%<\_FldPtr 2465500283456>%+%<\_FldPtr 2465500283968>%/2)*4/43560) \\f "%lu2">%
                        \\f "%lu2">%
bashing my head lol
Civil3D 2020
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: September 10, 2021, 10:04:55 PM »
Need to think a bit more but need something like
"%<\\AcExpr %<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-Objectid att)) ">%).TextString>% * 2 >%" for twice size
This was select blocks 1 attribute and add the attributes and put answer into a mtext.
(defun c:test ( / obj len area lay)
(setq lst '() x -1 str "")
(if (setq ss (ssget '((0 . "INSERT"))))
  (foreach att (vlax-invoke (vlax-ename->vla-object (ssname SS (setq x (+ x 1)) )) 'getattributes)
        (if (=(vla-get-tagstring att) "NAME")
        (setq str (strcat str "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-Objectid att)) ">%).TextString>%"))
  (repeat (- (sslength ss) 1)
        (setq str (strcat str "+%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-Objectid att)) ">%).TextString>%"))
(setq str (strcat "%<\\AcExpr " str " >%"))
(setq obj (vlax-ename->vla-object (car  (entsel "Pick Mtext obj"))))
(vla-put-textstring obj str)
(c:test)
You need to make the string and yes can use .textstring not fldptr, look at STR type !str.
kozmos
« Reply #5 on: August 17, 2023, 03:22:56 AM »
Is there a way to get the field pointer ID when we have field code such as "%<\\AcObjProp Object(%<\\_ObjId " (itoa (vla-get-Objectid att)) ">%).TextString>%"?
if yes, we can then use the FldPtr instead of using standard fieldcode when using AcExpr .
KozMos Inc.
