Author Topic: Run ATTSYNC only when block with attributes are present  (Read 1766 times)
w64bit
« on: September 08, 2021, 07:13:06 AM »
Hello,
I am trying to run ATTSYNC only when blocks with attributes are present.
Tried with this but it's not working.
Can anyone help, please.
(if (and (setq ent (entnext ent))
         (eq "ATTRIB" (cdr (assoc 0 (entget ent)))))
    (command "ATTSYNC" "N" "*"))
« Last Edit: September 08, 2021, 07:41:13 AM by w64bit »
mhupp
Re: Run ATTSYNC only when block with attributes are present
« Reply #1 on: September 08, 2021, 09:38:22 AM »
You will need to set blkname
(if (= 2 (cdr (assoc 70 (tblsearch "block" blkname))))
  (vl-cmdf "ATTSYNC" "N" blkname)
w64bit
« Reply #2 on: September 08, 2021, 10:48:06 AM »
Thank you but I need to check if any attribute blocks exists in the drawing, not a specific one.
« Last Edit: September 08, 2021, 11:05:35 AM by w64bit »
Lonnie
« Reply #3 on: September 08, 2021, 11:18:30 AM »
I'm pretty sure ATTSYNC ignores all blocks without attributes.
is there any reason you could not just use
« Last Edit: September 08, 2021, 03:02:08 PM by Lonnie »
w64bit
« Reply #4 on: September 08, 2021, 11:23:48 AM »
I receive the message: "This drawing contains no attributed blocks" (this message I want to avoid in order that ATTSYNC to continue).
If the drawing contains at least one attribute block, indeed ATTSYNC is ignoring blocks without attribute.
« Last Edit: September 08, 2021, 11:33:50 AM by w64bit »
« Reply #5 on: September 08, 2021, 11:49:01 AM »
Perhaps:
  1. (if (ssget "_X" '((0 . "insert") (66 . 1)))
  2.   (command "ATTSYNC" "N" "*")
  3. )
w64bit
« Reply #6 on: September 08, 2021, 12:15:28 PM »
Yes! Thank you very much.
« Reply #7 on: September 08, 2021, 01:36:12 PM »
Glad to help!
