Thanks sir very much about your great effort
i have some points about that and i need to add them to this lisp
i'll put it in points
1- Please note that columns (1-TOC , 2-H , 3-Floor ,4-Client,5-Project , 6-Branch ) They are variable from drawing to another and i make custom properties and they are fields then i need to make them be taken from properties of drawing not fixed as they be now .....and thanks about that sir
i attach an image about that
2-I need tubes length to be Rounding to the largest 0.50 metres and combine rows that have the same value of length and make the count column is sum of number of these tubes that have the same length ....
3-the poly line in client layer the length and area of it not appeared
4-Some layers and objects inside these layers not appeared and that change my quantities
5-I need it to ask me what it select all objects in the drawing or some objects that i can select
6-also i need the table to be updated automatically when i delete some objects from objects that i select or to delete some objects from the drawing if i select all in the drawing option that i said about in note no.(5) ..
7-the last thing is that i need to export the table to excel and make the name of excel file is the name of the drawing
in the last i really happy for your great work but it's notes to make it easier to me ...
thanks very much about that and i wait your new lisp ....
