Author Topic: How to make a shortest expression return T?  (Read 1967 times)
baitang36
« on: September 04, 2021, 08:42:22 PM »
An empty parenthesis returns nil
(setq a T)  return T
but it is too long
Re: How to make a shortest expression return T?
« Reply #1 on: September 04, 2021, 11:13:39 PM »
(setq a T)  return T
but it is too long
T
MickD
« Reply #2 on: September 05, 2021, 04:39:53 AM »
(quote T) ?
- John Carmack
- J.R.R. Tolkien
baitang36
« Reply #3 on: September 05, 2021, 09:56:22 AM »
(quote T) ?
i found shortest expression is (and)
(= t)
« Reply #4 on: September 05, 2021, 12:27:46 PM »
Thinking:
(t)
(eval t)
(and t)
baitang36
« Reply #5 on: September 06, 2021, 02:20:55 AM »
Thinking:
(t)
(eval t)
(and t)
(and)   not need t
(t) is wrong,   t is not a function
Marc'Antonio Alessi
  • Marco
« Reply #6 on: September 06, 2021, 03:44:25 AM »
_$ T
T
_$ (T)
; errore: funzione errata: T
_$ (
_$ (and T)
T
_$ (and)
T
_$ (eval T)
T
_$
CodeDing
« Reply #7 on: September 07, 2021, 10:37:12 AM »
baitang36,
...or you could just create your own short expression which will return T?
  1. (defun : () t)
  2. .....
  3. Command: (:)
  4. T
  5.
Best,
~DD
~DD
Senior CAD Tech & AI Specialist
Need AutoLisp help?
Try my custom GPT 'AutoLISP Ace'
« Reply #8 on: September 07, 2021, 11:21:39 AM »
Glad one of them worked. Sorry, I want around a computer at the time so I was just guessing on some of them (still a bit rusty at lisp).
baitang36,
  1. (defun : () t)
  2. .....
  3. Command: (:)
  4. T
  5.
Best,
~DD
:) Nice.
Also in that spirt (not as short but much the same--result wise).
(set ': (lambda nil T))
