Hello All,
I have an issue that popped up when I was separating code into respective libraries. I have a vs project called BasicWPF. Inside is a StyleDictionary for WPF XAML. I reference that resource dictionary elsewhere in other projects. I have applications that run outside of AutoCAD that run just fine.
The issue is when I run a project inside AutoCAD an Error pops up. It's pretty clear, a FileNotFoundException on BasicWPF, which is triggered from the ResourceDictionary reference in XAML. Now this BasicWPF is indeed in the project directory. I have another application in the same directory that references that dll and it runs just fine outside of AutoCAD.
Has anyone experienced this issue?
