Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Offset Point
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Offset Point (Read 1272 times)
ScottMC
Newt
Offset Point
on:
August 31, 2021, 10:42:46 AM »
Offsets from object start-point distance by pick or entry. If there's any suggestions.. Thanks for input! Source page: dubb..
https://www.theswamp.org/index.php?topic=52715.msg576003#msg576003
Agree BIGAL..
Code - Auto/Visual Lisp:
[Select]
defun
c:ko
newlen plotpt pt offset ang side
princ
\n
Insert Point using Offset."
ssget
"_X"
0
"ARC,LINE,*POLYLINE"
while
and
not
setq
ent
car
entsel
\n
>> Select *Line/Arc to Offset FROM >>"
getvar
"ERRNO"
52
setq
newlen
0
offset
0
;_ end of setq
setq
plotpt
getdist
\n
Enter/Pick Distance from Start of Reference: "
;_ end of setq
setq
offset
getdist
\n
Enter/Pick Offset Distance: "
;_ end of setq
setq
newlen
plotpt newlen
setq
pt
vlax-curve-getpointatdist
ent newlen
setq
ang
angle
0.0
0.0
trans
vlax-curve-getfirstderiv
ent
vlax-curve-getparamatpoint
ent pt
;_ end of vlax-curve-getfirstderiv
0
ent
t
;_ end of trans
;_ end of angle
;_ end of setq
initget
"A B I O L R"
setq
side
getkword
\n
Enter Side Above/Inside/Left or Below/Outside/Right [A/I/L/B/O/R]: <On> "
;_ end of getkword
;_ end of setq
cond
or
side
"A"
side
"I"
side
"R"
;_ end of or
setq
ang
ang
pi
2.0
or
side
"B"
side
"O"
side
"L"
;_ end of or
setq
ang
ang
pi
2.0
;_ end of cond
setq
obj
vlax
ename
vla-object
ent
setq
pt
polar
pt ang offset
entmakex
list
cons
0
"POINT"
cons
10
pt
cons
8
"non-print"
;_ end of list
;_ end of entmakex
;;(princ "\Point Added")
princ
;_ end of defun
EDIT (John): Added code tags.
Last Edit: September 03, 2021, 08:50:02 AM by ScottMC
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Re: Offset Point
Reply #1 on:
September 02, 2021, 08:52:24 PM »
1.5707963267948966192313216916395
(setq ang (+ ang (/ pi 2.0)))
or if lots of std angs
(setq pi90 (/ pi 2.0) pi45 (* pi 0.25) pi135 (* 0.75 pi) and so on.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Offset Point
