Author Topic: Flat pattern for cilyndrical inclinated branch  (Read 1881 times)
LULU1965
  • Mosquito
« on: August 26, 2021, 03:29:34 PM »
It's possibile with Lisp routine obtain a flat pattern with double inclination angle how in this attach picture.
Re: Flat pattern for cilyndrical inclinated branch
« Reply #1 on: August 26, 2021, 04:20:34 PM »
FLATSHOT command?
paulmcz
« Reply #2 on: August 26, 2021, 08:23:48 PM »
Yes, it is possible.
BIGAL
  • 40 + years of using Autocad
« Reply #3 on: August 26, 2021, 08:59:40 PM »
As a 17 year old got the pencil and paper out for this solution like probably others, there is unfold software out there it may be free or have a cost. Google
MickD
« Reply #4 on: August 26, 2021, 09:31:30 PM »
yes, look into 'Pipe Development' drawing.
I used to do hundreds (yes, literally :) ) of these in 2D in CAD, I set up template blocks with divisions etc to insert for known sizes, rotated the connecting pipe, did the projections and joined the dots, took all of a few minutes each and were dimensioned easily checkable for the checker.
You will find a lisp routine if you do a search but I never found one the did the dimensioning that allowed for fabrication or checking.
- John Carmack
- J.R.R. Tolkien
Jochen
« Reply #5 on: August 27, 2021, 03:53:14 AM »
Perhaps you should have a look at
www.ant-ares.de
Regards
Jochen
LULU1965
  • Mosquito
« Reply #6 on: September 16, 2021, 09:42:52 AM »
CORRUGATED 3D BRANCH
« Last Edit: June 16, 2022, 10:20:51 AM by LULU1965 »
paulmcz
« Reply #7 on: September 16, 2021, 05:41:21 PM »
Did you get the lisp you were asking about?
