Author Topic: how to use acedInvoke in AutoCAD 2007,2008 and 2009  (Read 1523 times)
guohq
« on: August 20, 2021, 12:07:20 PM »
Since AutoCAD 2011, the Application.Invoke method is provided. I want to implement this function in Autocad 2007,2008 and 2009, but acedInvoke does not seem to work.
       <DllImport("acad.exe", EntryPoint:="acedInvoke", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Auto), System.Security.SuppressUnmanagedCodeSecurity()> _
        Private Shared Function acedInvoke(ByVal args As IntPtr, ByRef result As IntPtr) As Integer
        End Function
here is the test code
(defun c:GetVariableValue(VarName)
   (eval (read VarName))
(Setq aa 1234321)
acedInvoke(New ResultBuffer(New TypedValue(LispDataType.Text, "GetVariableValue"), New TypedValue(LispDataType.Text, "aa"))
The above code runs fine in AutoCAD2010.
« Last Edit: August 20, 2021, 12:15:27 PM by guohq »
guohq
Re: how to use acedInvoke in AutoCAD 2007,2008 and 2009
« Reply #1 on: August 20, 2021, 12:47:42 PM »
sorry ,I use the wrong code. the right code is
acedInvoke(New ResultBuffer(New TypedValue(LispDataType.Text, "c:GetVariableValue"), New TypedValue(LispDataType.Text, "aa"))
