Author Topic: Handy way to deal with Osnaps, Draw-Dist-Move without the right click osnap pick  (Read 7420 times)
sourdough
This is my way, although simple, is my way of giving back to The Swamp. God knows how much
this site has given me insight and learning from others like yourself. I'm sure this could be refined, but
I leave that to the real pro's. I do mostly Survey Cad work and it does save some time. I call this a
little bit of a memory exercise ..... so how many short-cut commands do you memorize?
I have been running it in my Civil 3D since 2011 only encountered it not working when there
was an option within a command to use the number 1 [Enter].
Handy snap options - draw lines-plines and move and measure distance by Mike Perry Raleigh, NC
0 sets current layer = 0
11 sets snap = endpoint
2  sets snap = nearest
3  sets snap = node"
4  sets snap = endp node intersection perpendicular
5  sets snap = endpoint node intersection insertion perpendicular nearest
6  sets snap = endpoint nearest perpendicular
7  sets snap = off
8  sets snap = endpoint apparent intersection
*  opens Osnap dialog box
L* draws a line with you pick osnaps from dialog box and continue
pl* draws a pline with you pick osnaps from dialog box and continue
m* Move a with you pick osnaps from dialog box and continue
d* draws a line with you pick osnaps from dialog box and continue
prompt "\L0 will Draw line w-Point Object
Using a number 1-6 after L or PL or M or D  eg:  L1, PL1…. etc does that command with those osnaps
IF ANYONE KNOWS HOW TO MAKE A OSNAP CHANGE A TRANSPARENT FUNCTION FROM WITHIN A COMMAND, I WELCOME
YOUR PROGRAMMING EXPERIENCE.
« Last Edit: August 17, 2021, 01:24:53 PM by sourdough »
LDC 2009/C3D 2010/C3D 2011/C3D 2016
Win 10 64bit
Interesting concept(s) I'd like to toss up a concept for consideration as well; I would like to draw a pline and set the orthomode part way through the command (a fresh take on that age-old problem). I want to turn ORTHMODE off for the first two pickpoints and then turn it on.
I'll use some of my library tools to help me assemble this concept quicker.
First, a method to save myself some typing.
  1. (defun cmd (binding body)
  2.   ;; quick and dirty command generator.
  3.   ;; allows me to build a ``(defun c:foo () ...'' proced.
  4.   ;; this is only ment to save me some typing.
  5.   ;;
  6.   ;; By: John (7) K
  7.   ;;     10.16.07 12:31:06 PM
  8.   (eval
  9.     (append
  10.       (list 'defun
  11.             (read (strcat "c:" binding))
  12.             nil) body )) )
Next, I need a `pop` utility for list manuplications.
  1. (defun list-pop (lst / ~tval ~tpop )
  2.   ;;
  3.   ;; list-pop
  4.   ;;
  5.   ;; pops an item from a list
  6.   ;;
  7.   ;; Ex (given a list: (setq lis '(1 2 3 4 5 6 7 8 9 0)));
  8.   ;;  (list-pop 'lis)
  9.   ;;  > 1
  10.   ;;  ~~> '(2 3 4 5 6 7 8 9 0)
  11.   ;;
  12.   ;; By: John K
  13.   ;;
  14.   (setq ~tval (eval lst)
  15.         val (car ~tval))
  16.   (set lst (cdr ~tval))
  17.   val )
Now the assembly.
  1. (cmd "pl" '((setq
  2.              SETTINGS-LST- '("ORTHOMODE")
  3.              SETTINGS-LST- (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) SETTINGS-LST-))
  4.           (defun *error* (msg)
  5.               (command-s) (command-s)
  6.               (setq *sstack* nil)
  7.               (mapcar 'eval SETTINGS-LST-) )
  8.            (setq *sstack* (list '(setvar 'ORTHOMODE 0) '(setvar 'ORTHOMODE 0) '(setvar 'ORTHOMODE 1)))
  9.            (command "_.pline")
  10.            (while (eq 1 (logand (getvar "cmdactive") 1))
  11.                   (command pause)
  12.                   (eval (list-pop '*sstack*)))
  13.            (quit)) )
This is a very simplistic example and we can do the same thing for OSNAPS (for example) but we cannot do both (OSNAPS and ORTHOMODE) at the same time. We could fix this concept and work with association lists if there is interest.
sourdough
I found that using a Logitech G600 MMO Gaming Mouse and programming the Ortho and Osnap on the fly is possible. I apply also, ESC, Move, Regenall, Display order Up, Display order Down, Edit Label Style, etc... see attached programming.
I included my acad profile for this mouse preprogrammed.
Win 10 64bit
ribarm
  • Marko Ribar, architect
Glad for you...
Saddly, my scrolling wheel broke today...
Is there some better trick for doing : '_Z (zoom) command with single key stroke, perhaps through lisp, or ???
I can still press it as middle button, so panning works; simply I haven't used to press right button and then search for ZOOM from pop up...
And BTW. I have old gaming mouse (it has light bulb just in front of scrolling wheel - for better optical precision) and 2 keys on the left - never used them (I suppose they are for pg up / pg down)...
« Last Edit: May 27, 2022, 11:42:24 AM by ribarm »
M.R. on Youtube
https://www.autohotkey.com/
autohotkey is the bomb for redefining keys and making macros
