Author Topic: AutoCAD 2008 and 2018's princ are different  (Read 1745 times)
baitang36
« on: August 11, 2021, 02:25:49 AM »
The execution results of the following code under AutoCAD2008 and 2018 are different, and the generated file contents are different
  1. (setq fo (open "d:/tt.txt" "w"))
  2.  (princ (strcat "aaa" (chr 256) "bbb") fo)
  3.  (close fo)
In other words, the function princ of the higher version of autoCAD has been castrated,  princ has lost the ability to write binary data
Re: AutoCAD 2008 and 2018's princ are different
« Reply #1 on: August 11, 2021, 03:04:37 AM »
is the 2008 version you're testing with 64bit?
VovKa
  • Ukraine
« Reply #2 on: August 11, 2021, 05:39:51 AM »
i tested your code on acad2008 and the size of tt.txt is only 3 bytes
looks like my acad2008 is also 'castrated'
if you want to write 0 into the file then do it this way
    (foreach c '(97 97 97 256 98 98 98) (write-char c fo))
    (close fo)
or use 'ADODB.Stream'
baitang36
« Reply #3 on: August 11, 2021, 07:55:27 PM »
    (close fo)
thank you very much
baitang36
« Reply #4 on: August 11, 2021, 08:01:01 PM »
    (close fo)
After a test, this method can't write 10 to the file alone. It becomes 0D 0A .  one byte becomes two.
  2.     (foreach c '(97 97 97 256 98 10 98) (write-char c fo))
  3.     (close fo)
  4.
  5.
« Last Edit: August 11, 2021, 08:05:20 PM by baitang36 »
mm_clover
  • Mosquito
« Reply #5 on: August 12, 2021, 11:26:26 AM »
0A=10,Hexadecimal?
VovKa
  • Ukraine
« Reply #6 on: August 12, 2021, 03:38:28 PM »
    (close fo)
we can fool autocad the same way we did with 0
(foreach c '(97 97 97 256 98 266 98) (write-char c fo))
(close fo)
baitang36
« Reply #7 on: August 13, 2021, 03:21:29 AM »
(close fo)
ok
d2010
« Reply #8 on: August 13, 2021, 11:29:09 AM »
Can you found other solution?
Write char by char, into file-disk, you slow-down 100% entire Win10, because
many AntivirusPrograms, contain Real-LiveWatch of HardDisk
(close fo)
ok
baitang36
« Reply #9 on: August 15, 2021, 09:35:57 AM »
You mean, write many bytes at a time?.This may use the unpublished function of Acad, which can read and write binary files. The compiler in vlide is also implemented with lisp
