Author Topic: error compile fas  (Read 2284 times)
dgpuertas
error compile fas
« on: July 23, 2021, 03:49:33 AM »
When I try to compile various files (a lot) there are this error
Spanish
; error: vector de activación de modulo demasiado grande: 66350
; Make interrupido
Google transtale:
; error: module activation vector too large: 66350
; Make interrupted
If i do (foreach file (list .......) (vlisp-compile 'st file)))
run ok, but if I want to join in one fas file that error occurs  maybe size?.
Any idea?
Thanks a lot
ribarm
  • Marko Ribar, architect
Re: error compile fas
« Reply #1 on: July 23, 2021, 07:47:34 AM »
Maybe, you're right - size...
Have you tried to compile through VLIDE - Make Application... There are 2 options - simple and expert... I'd try with both of them and see output on check display - it should automatically pop up after processing compilation...
M.R. on Youtube
d2010
« Reply #2 on: July 23, 2021, 03:42:21 PM »
You view myAnswer, attached..
You read the Red-Messages, isInside Doc
Spanish
; Make interrupido
Google transtale:
; Make interrupted
Any idea?
Thanks a lot
« Last Edit: July 23, 2021, 05:21:28 PM by d2010 »
dgpuertas
« Reply #3 on: July 25, 2021, 12:19:58 PM »
If use make application that error shows:
Tipo de argumento erroneo symbolp 1
Bad argument type: symbolp 1
d2010
« Reply #4 on: July 26, 2021, 03:55:22 AM »
Please , you install the BrisCad202* and You compile the YourLisp with Blade .LspTo.Des.
because the "BladeFrom2020BrisCad", detect other/s error/s which
  Vlide2010AutoCad avoid or ignored same YourError/s.
Best Regards..
ribarm
« Reply #5 on: July 26, 2021, 04:52:28 AM »
I had no experiences with your particular error, but had problems when compiling with error ...something ... negative : -1... I solved this error by renaming lisp filenames to something short like : 1.lsp, 2.lsp, ... Then when compiling passed I also renamed x.vlx to something more intuitive like what it does : TSP-fast-new.vlx or TSP-fast-new.fas... I hope that your issue could be something that simple, but I don't know... Try it, maybe it helps after all...
M.R. on Youtube
dgpuertas
« Reply #6 on: July 27, 2021, 04:10:21 AM »
d2010, i have not Briscad, I use AutoCAD.
Finaly I create a vlx with the .fas files compiled separated and works. I prefer one fas file but  vlx its a solution.
Thanks all.
baitang36
« Reply #7 on: August 08, 2021, 07:19:07 AM »
Spanish
; Make interrupido
Google transtale:
; Make interrupted
Any idea?
Thanks a lot
Fas module consists of two parts, symbol table and function content. The size of the symbol table cannot exceed 65535. If it exceeds 65535, an error will occur. You can try dividing a large program into two
Multiple Fas can be merged into one FAS
You can use CMD commands
copy /b 1.fas + 2.fas 3.fas
« Last Edit: August 08, 2021, 07:25:06 AM by baitang36 »
d2010
« Reply #8 on: August 09, 2021, 01:39:59 AM »
Please you downloading a BrisCAD-version2021trial30days.
You execute the BLADE.
The first time, when I execute the "BLADE", i found many error/s. inside Big-Lisp.lsp
The Blade from Briscad , repair multiple error/s isInside Lisp.Ascii
Second. You make fas or .vlx
Thanks all.
« Last Edit: August 09, 2021, 02:17:50 AM by d2010 »
dgpuertas
« Reply #9 on: August 16, 2021, 07:52:43 AM »
Spanish
; Make interrupido
Google transtale:
; Make interrupted
Any idea?
Thanks a lot
Thanks a lot, i try to reduce the number of funtions (sure that any of them its not  in use)
Or create two proyect and compile separated.
Thanks a lot Baitang36.
ribarm
« Reply #10 on: June 27, 2022, 11:51:59 PM »
@Bai...
what are your next hacking plans?
M.R. on Youtube
